starting problems
Old Feb 27, 2013 | 05:05 PM
H Tech22a's Avatar
Default starting problems
I have a 94 Honda Prelude 2.2 SI that has starting problems sometimes it start sometimes it turns like it doesn't have any compression I've already changed the fuel pump the fuel filter and the main relay don't have any idea what it could be could someone give me a good reason for this problem
Old Feb 27, 2013 | 05:21 PM
dbd6604's Avatar
Default Re: starting problems
Why don't you do a compression test to determine whether or not you're actually getting compression. Might as well check for fuel at the rail and spark while you're at it. The more we know, the more we can help you.
Old Feb 27, 2013 | 05:32 PM
H Tech22a's Avatar
well I replace the plugs put new plugs in it and when it starts it hesitates for a few minutes then clears out and runs just fine and I can cut it off and start back 4 or 5 * but the next day will not start
Active EF
Feb 21, 2015 08:56 PM
ef roni
Nov 12, 2008 10:34 PM
lowlude34
Apr 4, 2008 07:35 PM
J-Brooks
Mar 9, 2006 06:31 PM
Goldfingiz
Aug 24, 2003 05:53 PM
