97 prelude engine swap
i put a h22a in a 97 prelude i did the timming belt tenioner swap to manule ten did valve job have aftermarket ecu with harness conv. dont have crank senser looked on her here alot of diffrent ways to make it all work i have a p28 ob1 ecu with jumper wire but my dist ob2 and inj ob2 can i make this work i used engine harness sensers inj all stuff off old ingine just not crank sencer becuse i was going ob1 ecu
Re: 97 prelude engine swap
I dont see why you would have any problems making this swap work on your 97 prelude...should start and run just fine as long as you did everything correctly meaning the engine harness and connectors
