lower ball joint help please! 98 prelude
http://imageshack.us/user/anthony.rocca.10
This is where I'm at, the caliper is removed from the lower control arm, but I can't seem to get the ball joint out. How do I get it out?
1 Post
Re: lower ball joint help please! 98 prelude
Normally a pitman puller would have that piece out:
put a pickle fork underneath the ball section of the ball joint on your lca:
get a gear puller to pull the top section of the joint off your hub.
http://www.autozone.com/autozone/acc...er=555664_0_0_
http://www.autozone.com/autozone/acc...uestid=1202025
Try heating that guy up with a blow torch and then use acetone (with gloves) and then try giving it a good whack. That didn't work for me so I had to resort to sawzall haha good luck these guys always give me lip.
In the FAQ section it covers how todo this with a 1/2 drive ratchet.
Or maybe its just a few threads down from here I forget. But I did
Just read about this trick. Put some extended ball joints in that
If its lowered and get your suspension geometry back.
InTheZoneAC
Suspension & Brakes
19
01-22-2014 05:21 AM
s-tech
08-06-2005 10:30 AM
