Temperamental '88
Old 09-18-2015, 08:35 PM
kids'honda's Avatar
Default Temperamental '88
My daughter recently bought an '88 Prelude and has been having trouble getting it to start every morning. The battery has been replaced, and it will start if you pop the clutch and then run like a champ all day. Next morning, it won't start without a jump or pop start. Took it to Auto Zone to test the distributor. Like I said, replaced battery. I suggested to her dad he pop the cables off battery since it is starting now, and reconnect and see if something is draining it overnight. If it does start right up in morning, what possibilities? Distributor, even though it tests fine when running? Cables? Help. And be gentle. This Mom has only a year of Engines in High School under her belt, and a bit of mechanical apptitude. Thanks.
Old 09-21-2015, 03:18 PM
holmesnmanny's Avatar
Default Re: Temperamental '88
It's possible the alternator is bad but the charging light bulb is burned out so you don't know it's not charging properly. It's also possible that the battery connections are corroded to the point that they aren't allowed a good connection.
bigandy90
01-02-2008 09:35 PM
hmtcrxsir
34
08-10-2007 12:21 AM
sonson6
06-12-2007 07:14 AM
Senbonzakura
04-16-2006 08:27 PM
riceanator01
05-08-2002 01:07 PM
Quick Reply: Temperamental '88
