Okay so for the past month I have been having an issue with the car making clicking noise when I turn right. I have been told it sounds like an axle problem which is weird because I just bought the axle brand new 2 months ago. This is the Driverside axle I'm referring to. So I check the axle and it was loose on the end that goes into the atts unit. I tried to push it in but it wouldn't go in all the way so I decided to remove it and inspect it. I took it off and noticed the splines on the female end of the axle looks a bit different from the splines on the atts unit. Can anyone confirm this is an Sh axle?
