96 prelude OBD2 Engine Swap help
i have looked for weeks about what engine swap i can do for my 96 prelude its got a blow h23a1 and i cant find much about 96 swaps that work with obd2 92-95 there are tons. from what i found i can use a h23a3 i just need to use alot of stuff from my h1 and make a spot for the knock sensor does anyone have any info that can help me get my prelude back on the streets plz and ty
Re: 96 prelude OBD2 Engine Swap help
I'm pretty sure the immobilizer didn't come out until 97, which makes things much easier for you.
you can get a h22a4, h22a, or h23a, then add the 2 wires for vtec, and get a 96 vtec ecu, and done. may or may not need to swap distributor and intake manifold for the h23a
i need the obd 2 to work cuz my state has emissions inspection on all obd2 cars 96 and up so will me putting in this obd1 engine pose any problems with that ik i need to swap the intake, knock sensor anything else? and this is the h23a3 engine im talking about i plan on using the h23a1 wire harness
1 Post
Just get the non vtec H23a or the H23a3 and transfer over the intake manifold, exhaust manifold, knock sensor its not there.
Everything else will work.
I got another question iv read sense my h23a1 is Obd2 it has a camshaft sensor the h23a3 is obd1 seems it don't have one how do i switch it over if its even possible?
vietdragontekx
08-02-2006 10:06 AM
