M2U4 SH ATTS Trans and M2B4 JDM H22 LSD Cases the Same? You decide!
I did some homework and it seems out of all the H/F transmissions there are only 2 transmissions that share both Bell housing case # of P16-1 on the transmission and the outter/main case of P16-1 M2B4 and all ATTS SH P6J M2U4/M2X5/M2R4. The earlier viscous LSDs m2b4 are only diffs to use a 14 bolt. Rest and newer LSD OEM H Trans use a 10 bolt. However the SH trans uses a 14 bolt.
We compared diff specs overall...height etc and seem to be real similar
SH trans in clutch housing has the Fins shaved from factory. The Head of the bolts in the SH trans stick a little further out. So I imagine needed slightly more clearance then M2B4 clutch housing.
Reason I am getting into this is I have a M2B4 missing a rear outter/case and am in search of one. P16-1
Full Transmission Bellhousing and Rear Case ID Chart. If you have any of the following Transmissions that I do not have a ID for please check your transmission and post up and will add to the list. There are 2 ID codes:
Bellhousing/Clutch Housing in Orange will be near the clutch fork and will Read P- something
Rear Case/Main Case in Blue will be above the passenger side axle seal inside the webbing and will Read P-something. It will be stamped upside down.
Post Up and I will update the List!
Trans: Bell Rear
M2A4 - JDM 4G P16-1/PX5-1
M2B4 - JDM 4G LSD P16-1/P16-1
M2F4 - USDM 4G. P16-1/PX5-1
M2U4 - JDM 5G Type-S ATTS/USDM Type-SH ATTS P16-1/P16-1
M2Y4 - JDM/USDM 5G Base. P16-1/PX5-7 same gearing/fd as T2T4 but non LSD
M2Z4 - JDM 5G SiR S-Spec/JDM 5G w/ LSD option P16-1/ it has a diff part number on rear case then rest reasembles P16-1 hmm?
T2T4 - JDM Accord SiR-T (F20B) LSD P16-1 /PX5-1
T2W4 - JDM Accord Euro-R LSD P16-1/PX5-7
U2Q7 - EDM Accord Type-R LSD. P16-1/PX5
M2T4 - BB6 H22A SiR LSD P16-1/PX5
P2T4 - CD6 Accord H22 non LSD same gearing/fd T2T4 P16-1/PX5
M2L5 92-96 Prelude S (F22A1) PX5/ PX5-2
M2S4 92-96 Prelude Si (H23A1) PX5-1/PX5-1
M2J5 92-96 Prelude Si (JDM F22B) PX5/PX5
P2A5 94-97 Accord DX/LX PX5-4/PX5-4 PX5-7/PX5-7
P2U5 94-97 Accord EX
P2A4 94-97 Accord Lx/EX Wagon PX5/PX5
M2J4 - EuDM 2.0i (F20A4) PX5/PX5
M2K4 - EuDM 2.3i 4ws (H23A2) PX5/PX5
M2F5 - EuDM 2.2i VTEC (H22A2) P16-1/PX5
M2X5 - EuDM 5g Vti-S (H22A5) P16-1/P16-1 - ATTS P6J
M2V5 - EuDM 5g Vti 4WS (H22A5) P16-1/PX5
M2P4 - EuDM 5g Vti-S 4WS P16-1/PX5 same gearing/fd as U2Q7 But non LSD
M2R4 - Vti-S 1999 updated? H22A8 P16-1/P16-1 ATTS P6J
M2C4 - 4th gen BA8 F22A2 PX5/PX5
Trans: Bell Rear
Re: M2U4 SH ATTS Trans and M2B4 JDM H22 LSD Cases the Same? You decide!
From my 97 Accord Coupe LX P2A5: PX5-7/PX5-7
ESP.net
10-27-2015 04:20 PM
