compression test
Old Aug 28, 2015 | 10:49 AM
stan xx's Avatar
Default compression test
after replacing timing belt and auto tensioner. I checked the compression. two (2) of cylinders were under 35 psi. Would it be better to have my cylinder head rebuilt or bye a used or rebuilt one? Any thing would be helpful! stan xx
Old Aug 28, 2015 | 12:22 PM
burnoutboy's Avatar
The Credible Hulk
Default Re: compression test
Your mechanical timing is VERY likely off a tooth or three. Check it and test again.
Old Aug 28, 2015 | 04:29 PM
ojasia's Avatar
Why was it you did the timing in the first place. ie. from broken belt? ie. bent valves. Or like ^^ he said timing off.
Wesleycrx
Dec 7, 2014 10:24 AM
MyWhiteEJ6
12
Nov 10, 2013 06:38 PM
lsv0892
Sep 7, 2011 09:56 AM
RockLee`
Oct 29, 2006 03:43 PM
jvtec95
Apr 14, 2005 04:29 PM
