Converting 1997 Prelude from ABS brakes to non-ABS
I'm wanting to remove the ABS pump, but I have a couple questions. There is a 4 port "proportioning valve" down by the fuel filter. Is this an actual proportioning valve or would it hurt leaving it, and at least temporarily (until I surely blow an engine, since my car is now boosted) replace the ABS pump with an Integra RS 4040 prop valve? The two lines that go to the front wheels run through the ABS pump and directly to the wheels, and the rear brakes are fed through the ABS pump then through the 4 port valve located lower.
Re: Converting 1997 Prelude from ABS brakes to non-ABS
Search for a thread on it by Thirsk66, he just did ABS delete on a 5th gen, and put all of the info he found down for others.
