01' SH ABS code #13
Old Dec 20, 2015 | 03:27 PM
cityjack's Avatar
Default 01' SH ABS code #13
Evening all,
I have an ABS code #13. LF wheel sensor. That is the only wheel I have the wheel weight on the inside of the wheel for balance. All the other three are on the outside of the wheel. Could that have anything to do with my code do you think? I thought the wheel sensor was looking at a pickup on my axle?
Any ideas?
Thanks
Sid
Old Dec 20, 2015 | 04:54 PM
minilogoguy18's Avatar
Default Re: 01' SH ABS code #13
The sensor is a hall effect sensor, the object in this case a toothed wheel that's used to disrupt the magnetic field of the sensor to generate the analog signal has to be close to the sensor since it's fairly low voltage and current. A wheel weight cannot interfere with this, it's probably a faulty sensor.
Old Dec 21, 2015 | 06:27 PM
cityjack's Avatar
Thanks mini. Any luck with your buddies 5th gen at work by any chance?
Have a good night.
Sid
Progen
Dec 27, 2013 02:26 AM
the.hamburglar
May 24, 2009 05:39 PM
2gnarly
Mar 1, 2009 03:24 PM
HondaHeddie
Sep 29, 2008 08:02 AM
Devo94ac
Jan 31, 2006 01:20 PM
