speedometer and odometer not working
Old Sep 17, 2015 | 04:42 PM
sublimeluder's Avatar
Default speedometer and odometer not working
What up guys I got a problem. I just changed the clutch and driver side axle. When I got it back together speedo wasn't working. Of coarse first thing I checked to make sure I plugged sensor back up. I also checked the wires and made sure it was getting power. I have since tried replacing with new vss sensors (2) neither worked. I also put car in reverse and let it roll back with sensor out to see if the gear or whatever turns the sensor and it turned. Any suggestions? Could the gear or whatever turns the sensor b broke even though it still turns in reverse?
Old Sep 18, 2015 | 06:45 AM
snobordboy's Avatar
Moderator
Default Re: speedometer and odometer not working
<p>Are you sure the VSS is seating all the way down and engaging the gear? It takes a little bit of wiggling it in correctly, especially if the o-ring is new. Also make sure not to over-tighten it, the ear on the vss body breaks VERY easily.</p><p>&nbsp;</p><p>Also double check that the plug is seated well, and the engine harness to body harness is connected completely.</p>
Old Sep 18, 2015 | 07:26 AM
AThanks for the reply. When I pulled trans/ axle I never removed the vss I only unplugged it. Are u supposed to remove the vss when your changing axles? The passenger axle went back in the trans really easy. But I had a hell of a time getting it back in the hub. I'm wondering if I could of damaged the gear from from beating it in lol. I'm not exactly sure how the gear is attached or how to go about fixing if so. The check engine light is on I'm gonna run codes after work. When I put my trans fluid back in I poured it in the CSS pressure release port. I've did this many times on diff vehicles. I wonder if that may have caused it
Old Sep 18, 2015 | 08:46 AM
Damn I hope Its not something inside the trans. The splines at the very end of the axle was messed up.(hub end) I had to take a dremel and go in between them. Then like a dummy I picked up the hub lined up splines and slammed it in place. Hmmm idkI also put a new axle on the drivers side. I wonder if the abs sensor that reads the axle could cause speedo not to work. Probably not the abs light would be on. Idk any suggestions
Edit: Im gonna try taking the bottom half of the vss off and go from there. From what I've read it should be one bolt holding it on
Old Sep 19, 2015 | 06:26 AM
Hey I think u may be wright about the vss gear not engaging. I only messed with the top half of CSS.(sensor only) I think when I put the axle in it pushed the bottom half (gear) out. I can see the oring and I'm assuming it should be pushed down inside the trans.
Edit. The oring I saw was for the top half its good. I pulled the complete assembly out cleaned and reinstalled. Everything looks good I even tested the wires again 2hot and 1ground.idk whatelse to do
Old Sep 19, 2015 | 06:06 PM
backinblue92's Avatar
I literally cut my abs lines off the spindles when I went 5 lug, so I highly doubt that's the source of your CEL.
Also I'm not understanding how if u unplugged the VSS that ur having this issue. When I did my tranny, I left the VSS in the tranny and simply unplugged the actual harness and 2 PS assist hardlines. Is that what u did, or u removed the entire VSS? I hear people who do remove the VSS to ensure it doesn't break, but that seems unnecessary work.
Also, the axles have alot of give. Ok nor alot, but if u have it in the tranny already and start pounding it into the hub, as long as you're not pounding directly back towards the tranny but have the spindle turned full left or right then the force won't distribute into the tranny. U want to drop the balljoint into the LCA, then hit the axle through from the rear. But I digress. You're past that point now.
It sure sounds like you've got a VSS-related problem. Might want to drain tranny fluid from the drain bolt and remove/refill until it comes out of the upper drain bolt.
Old Sep 19, 2015 | 06:33 PM
Thanks for the reply. Yea I just unplugged the vss harness when*removed trans/axles. I checked the cel code and it says vehicle speed sensor as I suspected. I also pulled the complete assembly out and everything looks good. I even tried manually turning the gear to see if MPH would read and nothing. I stuck a light tester in harness (3prong=3wires) 1 didn't light up. 1lit up dim and 1 lit up really bright. Which I figured 2 was hot and 1 ground. I'm gonna get an ohm reading tomorrow.
Old Sep 19, 2015 | 06:48 PM
Ok you're on the right track then. Check the FSM at s u p e r h o n d a just Google it. That'll give u values for the VSS I'm sure.
So my guess would be 12v constant, 5v reference control, and a voltage that will change with perceived speed. U said one didn't light up, so it could be the 5v reference control is just a ground, or it could be u yanked a wire.
U need the values to accurately fix this. If 2 new vss have not solved the problem, u may have yanked a wire by mistake and fubar'd it. U may need to backtrace into the harness. I personally would start with dumping trans fluid and filling from the upper drain bolt correctly. You could simply have too much fluid in there, submerging the VSS (if that's possible, idk, but just to rule out something stupid yknow lol).
If you're proficient in electrical diagnosis, this shouldn't be much difficult. May want to backtrace the VSS wires back into the engine harness a bit. Every point u test that ohms out, u eliminate the area up to that point. Make sense?
Old Sep 20, 2015 | 12:01 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
If you separated the electrical portion (with the P/S lines attached) from the base, chances are good that the small blade coupler that connects the lower shaft to the square male pin of the electrical sensor on top fell off when separated and you didn't realize it. If that is missing, you will need to find your original one or replace it.
In the future, I suggest removing the single bolt holding the entire VSS assembly to the transmission and gently twisting all of it out... and then lay it back toward the firewall/over the rear crossmember and out of the way. Do your work and then re-install it, being careful as stated above not to try and "pull" it into place using the single bolt... this usually breaks the mounting ear off. Lube the O-ring and push it in the hole with a back and forth twisting motion to seat it all of the way. Once seated properly, tighten the bolt.
Old Sep 20, 2015 | 01:08 AM
Just curious, why don't people just unplug the power steering hardlines and call it a day? Even the FSM recommends practically disassembling the VSS for a tranny removal. That's a time consumer.
Sure it'll leak a ton of PS fluid, but with a catch can under, it makes for a good time to change the PS fluid anyways. Or just some quick hands to plug the lines quickly.
Old Sep 20, 2015 | 05:51 AM
yungmulacrx's Avatar
Does the speedometer work when you put the car in reverse and reverse for 75 ft at about 10 mph? If it does I know your issue and will post up pictures if that's the case..
Old Sep 20, 2015 | 05:56 AM
I've got a 2000 base I just unplugged the vss harness and slave cylinder hardlines. Thanks for suggestions. I checked the shaft and gear is still attached
Old Sep 20, 2015 | 06:04 AM
I don't think so I'll go check though. What would cause that. Thanks
Old Sep 20, 2015 | 10:17 AM
I dunno what else to do guys. Its getting power so it must be the ecu. I guess I hooked my battery up before I plugged in the vss harness and the ecu didn't like it. I'm gonna stop by the junkyard in the morning and pick one up. I'll let ya know what happens.
Old Sep 20, 2015 | 10:28 AM
The issue I had was the vss gear on the differential was not pressed completely on.. when in reverse the gears together will push the gear back on the diff the correct way but as soon as you go forward the gear will come off(not completely) enough for it to not catch the sensor gear.. but this is a rare case and probably not your issue..
Old Sep 21, 2015 | 10:30 AM
Everything seems to be working like it should. Its getting power and gear is turning. I think I had the battery hooked up when I plugged vss in and it either fried the ecu or the gauge cluster. The junkyard didn't have the ecu or cluster. I may have found one in Knoxville about 2hrs away. Hopefully I can pick it up tomorrow and it'll fix problem idk.
Old Sep 21, 2015 | 05:34 PM
holmesnmanny's Avatar
If it was working before you unplugged it obviously this can only be either you broke one of the wires when unplugging it(perhaps it's inside the wire and you can't see it)or one of the pins on the connector is bad/bent or it's simply not plugged in all the way. My aftermarket vss's work great but it was a bit of a pain to plug them in all the way. I really had to put some muscle on it.
Old Sep 23, 2015 | 01:24 PM
I'm a idiot I tested the hot wires and they was good so I assumed the ground was good. I tested the ground today and sure enough no connection. I went and got a another wire harness and spliced it in. It worked hooray. Thanks for all the replies everyone your awesome.
PS I'm going to be updating my poor mans h22 build thread soon. I put in vacation Oct 8,9 and I'm gonna start rebuild
variablevalve
Aug 17, 2020 10:41 AM
y2kferari
Feb 16, 2010 09:51 AM
Rooftop voter
Jun 4, 2009 05:55 AM
b frisco
Mar 5, 2008 10:11 PM
Looose_R
Mar 27, 2002 04:49 PM
