5th Gen SH Strange Electrical or Immobilizer Problems?
Old 01-15-2016, 12:15 PM
flexoffender's Avatar
Default 5th Gen SH Strange Electrical or Immobilizer Problems?
having an issue with the car randomly shutting off (sometimes on idle/sometimes when driving) with the green key light flashing, also getting random dash lights coming on from day to day (either ATTS or the parking brake light) for no reason. it has shut off four times now while driving, when i try to start the car back up right away the entire dash flickers like crazy and makes almost like a clicking sound, the engine will fire and i can get the revs up but then it just dies again, yet i wait maybe 30 seconds and the car fires up fine and drives normally. as you can probably tell it's very nerve-wrecking as it happens randomly, anyone have anything similar happen? hoping to get to the bottom of it (thinking it could be electrical/ignition related?) the only thing recently replaced was the EGR valve, i thought that had fixed it but now two weeks later it shut off again...
Old 01-19-2016, 10:32 PM
BOOSTED_BB6's Avatar
Default Re: 5th Gen SH Strange Electrical or Immobilizer Problems?
It's possible your ignition cylinder is worn out. Do u have a lot of keys and keychains hanging off the car key? Or if your lucky it's just the ignition harness behind the cylinder that's faulty... I would try that. But before you should check all your grounds in the engine bay. Check the ground wires for corrosion and clean them. Certain ground wires can also be replaced. Check battery terminals. Also could be a main relay under dash driver side... lots of possibilities
Old 01-20-2016, 12:02 PM
No tears. Only dreams, now.
VashTheStampede's Avatar
I had a similar issue:
My rotor inside the distributor cap wasn't fastened on correctly, and the screw had come loose... this screw was apparently causing a short in the distributor or smacking the ICM. Check under the dizzy cap.
Check to make sure that your reverse light wire on the tranny isn't shorted. They come undone and will ground out on the tranny, shorting the whole thing out.
The ignition switch is a massive weak spot in these cars and causes all kinds of issues.
Finally, check your grounds. Also, may want to especially check your ECU grounds, as my ECU just decided to not power my car in the cold weather...
Old 01-22-2016, 10:14 AM
thanks for the replies, i will definitely go through and check all grounds, the strange thing is it never happens on shorter trips (to work for instance) only when i'm driving longer distances and when it's been idling a lot, but maybe that's just dumb luck.
Old 01-27-2016, 07:53 PM
dreski fellows's Avatar
I've had this same issue just a little less random only off throttle in 5th above 65 70..... But time wise it's totally random actually haven't seen it at all in about 3 months key is a lil worn though
Jigglz
09-18-2019 05:00 AM
aznfreakyguy
09-10-2007 01:02 AM
flyingv
02-20-2007 09:56 AM
Mike36
12-11-2006 08:03 PM
Accord95Lxxx
06-16-2005 05:31 AM
Quick Reply: 5th Gen SH Strange Electrical or Immobilizer Problems?
