H22 Removing Intake Manifold Butterflies
Yes i have searched and no i didnt find the answer i want......i did find that gains are seen by removing the butterfly plate and making a gasket to cover the low rpm runners....
my question is what to make the gasket out of....
i dont feel safe with normal gasket paper b/c it could rip and go inside easily....
but then again i think sheet metal would get very hot and negatively effect the whole cold air thing.....i also thought about the fact that the whole manifold is metal so what difference will it make.....i cant decide either way so now i am left with no gasket and no hp gains
anyone have any input???
thanks
thanks
where exactly did you find that there are gains?
i gotta search but i know he posted in the Dyno Page. he thought he would be helping his car by making this gasket. h22 + skunk2 stage 2 cams = 17x whp
edit: Found it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverEk3dr »</TD></TR><TR><TD CLASS="quote">My dyno.
Skunk2 stage II's
SS high compression valves.
Skunk2 springs.
Skunk2 titanium retainers.
Skunk2 camgears.
Hotshot 4-1 header
Removed butterflied from intake.
Shortram intake
Hondata s200.
Dyno'd in 3rd gear.
As you may already know. I made a gasket that covered up the 4 "short" runners in the intake. So I am sure that this dyno doenst do justice to the way my car runs. I havent went back to retune since. It went 14.20@97 on 17" street tires @ 2700 with me. Imagine it in an eg hatch @2000 pounds even.
P.s. The full swap is for sale
Modified by SilverEk3dr at 3:18 AM 12/5/2003</TD></TR></TABLE>
edit: Found it
Skunk2 stage II's
Skunk2 springs.
Skunk2 camgears.
Hotshot 4-1 header
Shortram intake
Hondata s200.
Dyno'd in 3rd gear.
i cant remember where i saw it, but it definately was there....hmmm.....you would think that blocking some of the runners would kill top end, but i have heard otherwise....im gonna look around a bit more but im pretty much spent on searching at this point....
1 Post
Re: (mgags7)
I know it will. Having smaller runners makes more low-end power, but as the RPMs go up, the engine needs more air, so you want bigger runners. The 2-stage IM accomplishes both of these concepts.
Here's my opinion: If you have a badass all-motor setup or a forced induction setup, you will probably benifit from taking out the butterflies, but for a lightly modded daily driver, the missing low-end doesn't make up for a negotiable amount of mid/high-end power.
Re: H22 Removing Intake Manifold Butterflies (mgags7)
I have read that removing them may net you something little at the cost of lots down low, but did not read about blocking off the short runners too...
Re: H22 Removing Intake Manifold Butterflies (codeh22a4)
It definitely works. Low end lost but mid to top end is great. Good mod with cam upgrade and headwork.
http://blacktrax.net/btp_H22_IM.html
blacktrax, your boring service looks good, can i send you the tb i am having bored out and you match the mani to that? cant wait to see the dyno, ill probably get the bore when i see that....thanks
Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">blacktrax, your boring service looks good, can i send you the tb i am having bored out and you match the mani to that? cant wait to see the dyno, ill probably get the bore when i see that....thanks</TD></TR></TABLE>
No problem, bring the t/b or the t/b gasket and we can do it for you. Just give us a call 408.946.2900
Re: H22 Removing Intake Manifold Butterflies (vinuneuro)
what? this makes no sense. blocking 4 of 8 runners won't make more power!? you're reducing the volume of air the manifold can flow
Re: H22 Removing Intake Manifold Butterflies (satan_srv)
What about removing the butterflies AND gutting the ports so that it's one big massive hole instead of 8 separate holes?
A train of thought is that this is negligable since air will always flow through the path of least resistance (the inner/shorter ports).
Re: H22 Removing Intake Manifold Butterflies (somboa)
loss of velocity and torque...it's been done and it doesn't make more power...maybe I little on top but less through the powerband
Us talking about it : https://honda-tech.com/zerothread?id=634796
junbb1 reporting his losses on the dyno https://honda-tech.com/zerothread?id=648786
Shiet... dyno proven to lose power. I'm running mine like that too (removed butterfly plates).
Maybe it's time I put them back on... or I could go with the Skunk2.
ok now i have the skunk2, and its wide open inside, tell me how thats any different from removing the iab plates? other than larger ports and runners, theres pretty much no difference, so if youre losing power with the plates out, then you'll just loose more power with the skunk, considering you'll have double the air coming in, is this not correct???
1 Post
Re: H22 Removing Intake Manifold Butterflies (WillsH22Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WillsH22Accord »</TD></TR><TR><TD CLASS="quote">ok now i have the skunk2, and its wide open inside, tell me how thats any different from removing the iab plates?</TD></TR></TABLE>
I don't think the runners of the S2 manifold are as big as the stock mani completely bored out, so the difference is there, just not as much of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WillsH22Accord »</TD></TR><TR><TD CLASS="quote">ok now i have the skunk2, and its wide open inside, tell me how thats any different from removing the iab plates? other than larger ports and runners, theres pretty much no difference, so if youre losing power with the plates out, then you'll just loose more power with the skunk, considering you'll have double the air coming in, is this not correct???</TD></TR></TABLE>
runner length and diameter...
well what i did was to remove only the butterflys but the butterfly plate is still there i just pulled the 8 butterflys out
my post was referring to somboa, he said he has the butterflies removed and it sucks, so he might get the skunk, but wouldnt that be pointless? because having the iabs removed would be very similar to having an aftermarket IM correct?
no, the iabs removed on the stock mani flow way too much down low and pretty much the same up top, like no real diff...the skunk2 is obviously comparable in flow up top since it doesnt rly change the hp too much, but i would think the stocker would do better than the s2 down low b/c of the iabs....
Re: (mgags7)
the skunk 2 intake manifold kicks ***. massive air flow. way better than any possible modification you could do to the stock intake manifold and removing intake air bypass butterflies.
Re: (WillsH22Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WillsH22Accord »</TD></TR><TR><TD CLASS="quote">my post was referring to somboa, he said he has the butterflies removed and it sucks, so he might get the skunk, but wouldnt that be pointless? because having the iabs removed would be very similar to having an aftermarket IM correct?</TD></TR></TABLE>
no
8 ports with 2 different lengths, more surface area and overall volume, and obstructions to flow between all 8 ports
vs.
4 optimally sized ports for volume, 1 length, no obstructions.
no
vs.
