Should i boost?
Old Nov 2, 2004 | 08:36 PM
Lude_Behavior_97's Avatar
Default Should i boost?
I have a ' 97 prelude with 106,xxx miles and i am thinking of boosting. I needed to know if i can run 5-6 pds of boost without frying the motor. Anyone good compression ### so i can compare a +\- average.
Old Nov 2, 2004 | 08:37 PM
ludetech
Guest
Posts: n/a
Default Re: Should i boost? (Lude_Behavior_97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lude_Behavior_97 &raquo;</TD></TR><TR><TD CLASS="quote"> Anyone good compression ### so i can compare a +\- average.</TD></TR></TABLE>
huh?
john d
Guest
Posts: n/a
please search: https://honda-tech.com/zerothread?id=316373
can i have my 2% back lol
Modified by john d at 6:16 AM 11/3/2004
Old Nov 2, 2004 | 09:18 PM
AndyD's Avatar
I say no to boost.
Old Nov 2, 2004 | 09:27 PM
john d
Guest
Posts: n/a
Default Re: Should i boost? (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">I say no to boost. </TD></TR></TABLE>
boost
Old Nov 2, 2004 | 10:04 PM
SKDRCR's Avatar
Default Re: Should i boost? (john d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">can i have my 2% back lol </TD></TR></TABLE>
Maybe you should put that in your sig.
It seems like you put that with every response you have
along with search and lock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lude_Behavior_97 &raquo;</TD></TR><TR><TD CLASS="quote">I have a ' 97 prelude with 106,xxx miles and i am thinking of boosting. I needed to know if i can run 5-6 pds of boost without frying the motor. Anyone good compression ### so i can compare a +\- average.</TD></TR></TABLE>
Yes, you can boost 5-6 lbs on a stock motor but I would recommend
using a good stand alone system even with only 5-6 lbs of boost.
As far as compression numbers, I would say anywhere from 210 to 180 psi
Make sure each cylinder is close in comparison though
Old Nov 2, 2004 | 10:12 PM
Matgallis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">I say no to boost. </TD></TR></TABLE>I say no to 4ws
Old Nov 2, 2004 | 10:15 PM
SKDRCR's Avatar
Default Re: Should i boost? (Matgallis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matgallis &raquo;</TD></TR><TR><TD CLASS="quote">I say no to 4ws</TD></TR></TABLE>
wurd
Old Nov 3, 2004 | 12:20 AM
pentaq's Avatar
Default Re: Should i boost? (SKDRCR)
I say yes to boost and 4WS
Old Nov 3, 2004 | 05:34 AM
john d
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
haha arlight ill chill out with that stuff
but seriously, b st
Old Nov 3, 2004 | 06:06 AM
Carbon_Lude98's Avatar
compression and leak down test first..if it looks good then i would boost.
Old Nov 3, 2004 | 06:25 AM
AndyD's Avatar
HAHAHA, you are still mad at me from the last turbo thread, aren't you. lol
Don't think I am against boost. I'm not. I am just not for it on NA designed Honda motors. As a matter of fact, I plan to boost my car in the near future....just not the Prelude.
xtremvw
Jun 4, 2008 09:11 AM
95teg_ls
Nov 16, 2006 02:32 PM
one slow coupe
Mar 19, 2006 05:52 PM
LSVtechnologytur...
May 2, 2005 05:18 PM
pg_thao
Apr 10, 2003 09:34 AM
