F22
Old Nov 4, 2004 | 12:55 AM
wAnNaBe4VTEC's Avatar
Default F22
hey i'm new to this...not much knowledge on my lude but i'm willing to learn...anyways, anyone in here own a F22 SOHC engine...no talk about it all i here is h22 swap or h23 tech...no one likes the F22 ? ...
Old Nov 4, 2004 | 06:18 AM
bdwvteconly's Avatar
Default Re: F22 (wAnNaBe4VTEC)
is it a vtec or non vtec
Old Nov 4, 2004 | 06:33 AM
Paul H22A4's Avatar
Default Re: F22 (BB6 JDM LUDE)
F22 is non vtec
Old Nov 4, 2004 | 08:43 AM
TraKtioN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wAnNaBe4VTEC &raquo;</TD></TR><TR><TD CLASS="quote">hey i'm new to this...not much knowledge on my lude but i'm willing to learn...anyways, anyone in here own a F22 SOHC engine...no talk about it all i here is h22 swap or h23 tech...no one likes the F22 ? ...</TD></TR></TABLE>
Theres no point in modding the f22, its a torqy engine but has no top end at all, I should know I have one. At 135 hp stock with a lame 8.9:1 compression, paltry 6200 redline, and long gears...its not worth anyones time but a possible cheap turbo application.
Old Nov 4, 2004 | 09:32 AM
this engine is slow but it still running after 256k...but yea true maybe just a cheap turbo but i was just wondering if anyone has a F22 in the forum...thanks for the replies though..
Old Nov 4, 2004 | 09:56 AM
PirateMcFred's Avatar
I have an F23...sorta. Look for a user called Bisimoto, he is making awesome NA power with the F22A1. He has some nice drag records.
Pirate
Old Nov 4, 2004 | 10:39 AM
LudeyKrus's Avatar
The F22's not that bad.
It has the H23's 95mm crank, a nice low compression ratio from the factory, and doesn't have FRM..........sounds like a good forced induction motor to me!
I actually wanted to scoop up a cheap F22 lude and do a ghetto turbo setup to see how much power I could squeeze out of it. The motors are dirt cheap, so breaking stuff wouldn't be a huge deal.
Oh, and also: the DSM junkyard turbo setup for the Prelude will bolt up to the F22 as well as the H23.
Old Nov 4, 2004 | 11:20 AM
prelude9384's Avatar
Default Re: F22 (TraKtioN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TraKtioN &raquo;</TD></TR><TR><TD CLASS="quote">
Theres no point in modding the f22, its a torqy engine but has no top end at all, I should know I have one. At 135 hp stock with a lame 8.9:1 compression, paltry 6200 redline, and long gears...its not worth anyones time but a possible cheap turbo application. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TraKtioN &raquo;</TD></TR><TR><TD CLASS="quote">
Well lets see the "lame" compression as you put it is pretty nice if you're doing a turbo set-up. The dying out on the top can be solved by putting a beefier cam in namely a delta regrind. Go ask all the f22 accord guys, they love them. As for redlining, I think all preludes have around the same redline? I could be wrong. Actually I like the long gears, it's the same tranny as the SI. I mean the f22a1 is not a good idea at all for a NA set-up, but then again what's the fun being NA. I think the f22 is a model motor to boost expect for the fact being it's SOHC.
Old Nov 4, 2004 | 11:33 AM
ZigenBallz's Avatar
Default Re: F22 (PirateMcFred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote"> Look for a user called Bisimoto, he is making awesome NA power with the F22A1. He has some nice drag records.
Pirate</TD></TR></TABLE>
I think he's moved onto an F18A now... still making 300whp though... with a 1.8l...
Old Nov 9, 2004 | 08:41 PM
Valdi01's Avatar
Yea i own a f22 its a dohc one with mild cams, port and polished head and air induction its doesnt go to bad for what it is. It just has no high rev power like in first once you get passed 5500 revs it goes no where. Not bad cars though just depends what you want it for. Its not what i want it for so im selling it.
Old Nov 11, 2004 | 05:53 PM
Col. K0rn's Avatar
Default Re: F22 (Valdi01)
Yeah, I have an F22A1 that has over 219K miles on it, and it smokes more than Dennis Leary doing standup! I got the car hella cheap on a dealer trade, $500.
I have a buddy who has an H23 that he took out of his 93 Si; it puked a rod, scorched the crank and dinged the block a bit. I'm debating making a hybrid out of the two.
My intended application is to boost it on down the road, once the engine is together.
Before I get flamed, which is the better of the two blocks? I know that I'll have to have machine work done to them both, but the F22 is currently running. I think the rings are sticking, and it's just plain worn out.
Old Nov 11, 2004 | 06:24 PM
TraKtioN's Avatar
Default Re: F22 (Col. K0rn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Col. K0rn &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I have an F22A1 that has over 219K miles on it, and it smokes more than Dennis Leary doing standup! I got the car hella cheap on a dealer trade, $500.
Well the h23 is closed deck vs f22 which is open, closed decks are great for FI. It also comes with slightly larger pistons, along with knock sensor and oil cooler which the f22 does not have stock but can be added.
xxredpreludesixx
May 3, 2005 05:49 AM
mp15_LUDE
Apr 15, 2005 10:47 PM
two fast 4 you
Dec 28, 2003 08:23 PM
HyperFlow
Jul 16, 2003 07:01 PM
rota426
Feb 16, 2002 07:58 PM
