replacing fuel filter
Old Nov 7, 2004 | 08:06 PM
MartinLude's Avatar
Default replacing fuel filter
I have a 92 prelude and I want to replace the fuel filter. How do I do it?
Old Nov 7, 2004 | 08:14 PM
speedracer9k's Avatar
Default Re: replacing fuel filter (MartinLude)
on the fire wall there is a black plastic case thats is kind of round (hard to explain). it is bolted to the firewall. There is a fuel line running from it to the fuel rail. take off the banjo bolt on the top, should be 17mm. then the fuel line will come off. make sure to replace the 2 washers. Then take off the 2 bolts that connect it to the firewall. then do the opposite to put then new one on. takes about 30 minutes max.
Old Nov 9, 2004 | 03:30 PM
Default Re: replacing fuel filter (speedracer9k)
wow, i hate when people post and never reply when someone gives them an asnwer
Old Nov 9, 2004 | 03:33 PM
DarkBB4's Avatar
hey.. thanks bro
just wondering.. I heard u need to use a flare nut wrench (line wrench).. to get some of the bolts off?
this true?
Old Nov 9, 2004 | 03:36 PM
Yield's Avatar
it's recommended, otherwise you'll round it off cause it's real soft. Be very careful lining up the new filter too. If it's not perfectly lined up and you try to screw the line back it it will strip. Don't force it at all.
moonpieboy
Oct 9, 2005 09:57 AM
94DOHCDELSOL
Feb 4, 2005 11:00 AM
get wet racing
Jan 6, 2003 06:16 AM
civbeater90
Aug 27, 2002 09:00 AM
AK94GSR
Aug 7, 2002 08:02 PM
