DIFFERANCE BETWEEN THE SH ENGINE BLOCK AND REGULAR ONE
Old Nov 5, 2004 | 07:26 AM
TCPRELUDE's Avatar
Default DIFFERANCE BETWEEN THE SH ENGINE BLOCK AND REGULAR ONE
HI, IM GETTING A NEW ENGINE BLOCK PUT IN MY 2000 PRELUDE ON MONDAY BY HONDA. I REALLY WANTED THE SH ENGINE BLOCK PUT IN INSTEAD OF THE REGULAR ONE BUT I DIDNT KNOW IF ANY OTHER COMPONENTS HAD TO BE CHANGED FIRST. I ALSO WANTED TO KNOW WHAT THE DIFFERANCE IS BETWEEN THE THE SH ENGINE BLOCK AND THE REGULAR ONE.
THANKS!
Old Nov 5, 2004 | 07:36 AM
BrokeLude's Avatar
Default Re: DIFFERANCE BETWEEN THE SH ENGINE BLOCK AND REGULAR ONE (TCPRELUDE)
DO YOU HAVE AN SH OR BASE PRELUDE? THERE ARE DIFFERENCES IN THE ACTUAL DESIGN OF THE BLOCK AND THE SH BLOCK WILL NOT FIT A BASE TRANSMISSION WITHOUT MODIFICATION AND VICE VERSA. IF YOUR CAR IS A BASE, THERE IS NO REASON TO PUT IN AN SH UNLESS YOU ARE CHANGING THE TRANNY AS WELL. IF YOU WANT THE ADVANTAGES OF THE SH TRANNY, YOU ARE BETTER OFF PUTTING IN THE BASE ALONG WITH A QUAIFE LIMITED SLIP DIFFERENTIAL.
Damn, typing all caps makes my eyes hurt...
Old Nov 5, 2004 | 07:40 AM
00LudeLover's Avatar
Default Re: DIFFERANCE BETWEEN THE SH ENGINE BLOCK AND REGULAR ONE (BrokeLude)
sh engine also has linkages for the ATTS, the actual engine thought is almost identical. It isnt like the difference between a normal engine and then one with vtec, you dont get any gains out of dropping an sh engine into a base prelude.
WHY ARE YOU LETTING HONDA PUT YOUR NEW ENGINE IN, I HOPE IT IS WARANTY, BECAUSE THEY ARE GOING TO OVER CHARGE YOU.
THANKS!!!
AndyD's Avatar
WHY DO YOU WANT A TYPE SH BLOCK OVER A BASE BLOCK??
Old Nov 5, 2004 | 07:42 AM
Gerhard_001's Avatar
oil filter location, ATTS mounting holes that prevent an axle carrier bearing being directly bolted to the block with out fabrication, all else is identical. If it is a base prelude then it would be piontless to put in an SH block because you get 0 gains.
Old Nov 5, 2004 | 07:56 AM
PrettyLude's Avatar
turn off ur caps lock button
Old Nov 5, 2004 | 09:44 AM
TCPRELUDE's Avatar
I ALSO WANTED TO KNOW HOW I CAN INCREASE THE TORQUE OF THE NEW ENGINE ONCE INSTALLED WITHOUT DOING ANY MAJOR ENGINE WORK. I KNOW THAT THE SH HAS AN ACTIVE TORQUE TRANSFER SYSTEM IN IT. DOES THAT INCREASE THE TORQUE?
Old Nov 5, 2004 | 09:47 AM
TCPRELUDE's Avatar
Default Re: DIFFERANCE BETWEEN THE SH ENGINE BLOCK AND REGULAR ONE (00LudeLover)
THEY ARE PAYING 75% OF THE WORK AND I AM OUT OF WARRANTY. THEY ARE REALLY HOOKING ME UP BY DOING THIS.
Old Nov 5, 2004 | 09:57 AM
Paul H22A4's Avatar
Default Re: (TCPRELUDE)
No, ATTS does not increase engine torque output.
ATTS transfers torque to the inside wheel during hard turning to reduce understeer.
Edit: For more power: https://honda-tech.com/zerothread?id=1029795
Modified by Paul H22A4 at 1:10 PM 11/5/2004
Old Nov 5, 2004 | 10:29 AM
BrokeLude's Avatar
Default Re: (Paul H22A4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul H22A4 &raquo;</TD></TR><TR><TD CLASS="quote">ATTS transfers torque to the inside wheel during hard turning to reduce understeer.</TD></TR></TABLE>
Outside wheel
Old Nov 5, 2004 | 10:30 AM
Paul H22A4's Avatar
Default Re: (BrokeLude)
whoops, yea.
Old Nov 5, 2004 | 10:31 AM
97lude's Avatar
https://honda-tech.com/zerothread?id=762014
Old Nov 5, 2004 | 11:36 AM
Default Re: DIFFERANCE BETWEEN THE SH ENGINE BLOCK AND REGULAR ONE (97Lude)
omg....
1. turn off caps
2. Learn what ATTS does
3. Get the engine that was in your car originally. The other one is not better than the other. It just depends what type prelude you have.
4. turn off caps.
Old Nov 5, 2004 | 12:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TCPRELUDE &raquo;</TD></TR><TR><TD CLASS="quote">I ALSO WANTED TO KNOW HOW I CAN INCREASE THE TORQUE OF THE NEW ENGINE ONCE INSTALLED WITHOUT DOING ANY MAJOR ENGINE WORK. I KNOW THAT THE SH HAS AN ACTIVE TORQUE TRANSFER SYSTEM IN IT. DOES THAT INCREASE THE TORQUE?</TD></TR></TABLE>
Ok dood, You cannot simply just slap ATTS on your car if it is a base. You have front suspension components to clear the ATTS unit that would need to be replaced, and then it is a nightmare to wire all the sensors that are associated with ATTS and after that you have to purchase a new ECU so you can plug in the ATTS ecu into it. So you would be looking at 6000.00-7000.00 if you wanted to do this, do you think that is cost effective for something that gives you no power benefit?
Stop asking questions that if you used the search button, would have answered all your questions on this matter. And stop using the caps lock.
Apocolipse269
Apr 22, 2017 12:06 PM
laloquera916
Aug 16, 2015 10:03 AM
ludejaime
Jul 3, 2007 06:09 AM
92 civic VX B18c
Jul 21, 2003 11:43 AM
RedLude2
May 10, 2002 09:47 AM
