V-AFC experts
Old Nov 4, 2004 | 07:11 PM
Beau Gotti's Avatar
Default V-AFC experts
well my lude was equipped with the V-AFC when i bought it, well a few days after having it, the check engine light came on, reset the ecu, it went off for a few days, came back on, ran the code it is throwing a P1259 "Manufact. control fuel air metering." which is saying it is the V-afc, my buddy told me i need to flat line the fuel to like full throttle, but im not positive if that was his exact words, i need to know what to do about this, and directions on how to do it (ex. settings - blah - blah - blah) thanks alot
beau
Old Nov 4, 2004 | 10:20 PM
Paul H22A4's Avatar
Default Re: V-AFC experts (beaussol)
Dyno tune it.
Old Nov 4, 2004 | 10:35 PM
satan_srv's Avatar
adjust all your maps to 0% for all positions until you tune it
Old Nov 5, 2004 | 05:51 AM
Beau Gotti's Avatar
its already been tuned. not sure by who, or where, but i can find out in a few and i will post, how do i get to the maps, i know its in settings but where after that
Old Nov 5, 2004 | 10:12 AM
justanotherlude's Avatar
I think you can try to go to the apexi website and get the operating manual to help you set it to 0....
Old Nov 5, 2004 | 12:19 PM
Beau Gotti's Avatar
i need to know how to get to what ever that needs to be set to zero...i dont need to know how
beau
Old Nov 5, 2004 | 01:27 PM
ITSME4G63's Avatar
Default Re: V-AFC experts (satan_srv)
yup, just set everything to 0% on low and hi throttle, until you get some sort of dyno tune or wideband. I have a normal afc, but it should be the same, if you are the the screen that displays your revs and throttle %, hit "back" button until you get to the menu where you can see settings, then go to low throttle and move the cursor right as you go on though 1-8k rpms press up or down to make it a steady line so you do not see any bar graph type colums. do that for low and high throttle and youll be fine. Sorry if I didn't explain it clear enough.
Old Nov 5, 2004 | 05:13 PM
superturboprelude's Avatar
what about the throttle percentage it says 10 and 50% so set all that to 0 too?
Old Nov 5, 2004 | 05:21 PM
99_SH's Avatar
Default Re: V-AFC experts (superjunprelude)
10%/50% is fine.
Check this site out. http://geocities.com/araxtypesh/
mrEM1
Mar 7, 2006 04:59 PM
smkngsr
Apr 11, 2005 05:58 AM
Jason kiDD
Mar 25, 2005 11:01 AM
b16a27
21
Jan 13, 2005 03:16 PM
IgniteTeg
May 3, 2002 01:22 AM
