problems getting into gear
Old Nov 2, 2004 | 05:40 PM
imransprelude's Avatar
Default problems getting into gear
I'm having problems in the morning trying to get in gear...it only happens when the car is cold...what could it be?
master/slave cylinder? my fluids are fine
thanks
Old Nov 2, 2004 | 06:51 PM
napalm_srv's Avatar
Default Re: problems getting into gear (imransprelude)
its something these honda's do...if it happens to u again...try letting the clutch out and then pushing it back in...then go into gear...also search next time..i know this answer cause i searched
Old Nov 2, 2004 | 10:19 PM
SKDRCR's Avatar
Default Re: problems getting into gear (napalm_srv)
Let your car warm up before you drive it.
Old Nov 3, 2004 | 12:10 AM
vtec92lude's Avatar
I have a similar prob getting into first now and again. I just deal with it. I really dont think it is anything to worry about (correct me if im wrong please)
Good luck
Old Nov 3, 2004 | 04:33 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: problems getting into gear (vtec92lude)
Prelude 5spd trannies are notorious for that, it's a common thing. If it happens again, just put it back to neutral, then back into first.
Happened to me in my 5th gen all the time.
Old Nov 3, 2004 | 05:35 AM
thelarkascend1ng's Avatar
Default Re: problems getting into gear (Sticky Tires)
happens every once in a while to my 4th gen. not a big deal, i don't think.
Old Nov 3, 2004 | 03:34 PM
Default Re: problems getting into gear (thelarkascend1ng)
its pretty bad and I do let it warm up...and this happens everyday
Old Nov 3, 2004 | 04:07 PM
homesauce's Avatar
put it in second gear first, then put it in first.
Old Nov 3, 2004 | 04:20 PM
ernestoG's Avatar
Default Re: problems getting into gear (homesauce)
do the 1 to second thing and also ...on my car anyway I let the clutch out a tiny bit, not enough to grind but it seems to let it in gear for me.
I have the problem usually in reverse though and it always helps me out.
Old Nov 3, 2004 | 10:36 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homesauce &raquo;</TD></TR><TR><TD CLASS="quote">put it in second gear first, then put it in first.</TD></TR></TABLE>
This used to work for me when my old tranny had
troubles going into first
JDM_EK4_Coupe
17
Apr 12, 2007 12:37 PM
GReddy212
Sep 26, 2006 06:02 AM
Leithen
May 29, 2005 07:00 AM
missinghubcabs
Jun 25, 2003 03:41 PM
