Problem with header nuts and stud.
Old Nov 5, 2004 | 05:18 PM
GranPrix's Avatar
Default Problem with header nuts and stud.
My self-locking nuts were a mission to take off, I had to use an impact wrench and a impact chisel. Any way, one was so tight that the entire stud came out of the block and the sutd is damaged. Do I really need to use all 9 nuts, or can I use a regular bolt with a locking washer to replace the damaged stud?
Thanks guys
Old Nov 5, 2004 | 06:37 PM
speedracer9k's Avatar
Default Re: Problem with header nuts and stud. (ACCH22)
you can try to use that, but if the header doesn't seal with the gasket your going to have an exhaust leak and burn up your exhaust valves.
civicdelsol33
Jul 19, 2007 03:29 PM
2005 TSX
May 2, 2005 06:01 PM
tuan...
Feb 27, 2004 03:20 PM
ebelp
Jul 29, 2003 10:21 AM
ScottEK
Aug 25, 2002 02:53 PM
