vafc 2 throwing a map code 3 ?
Old Nov 3, 2004 | 08:47 PM
superturboprelude's Avatar
Default vafc 2 throwing a map code 3 ?
ok i just got my vafc 2 and i went to turn the fuel up and it threw a code 3 which is map sensor is this cause its wire wrong or is it cuz i am running too richen and need to turn the fuel down and also the cel only comes on when im accell to 7000 rpm and it comes on what can i do tto fix it
Old Nov 3, 2004 | 08:53 PM
@ries's Avatar
Default Re: vafc 2 throwing a map code 3 ? (superjunprelude)
make sure you have the perameters set correctly in the vafc... then check your wiring. if you are adding too much fuel then that can cause the cel.
Old Nov 3, 2004 | 08:55 PM
Default Re: vafc 2 throwing a map code 3 ? (@ries)
what you mean by parameters what settings
Old Nov 3, 2004 | 08:56 PM
so youre saying if i set the fuel wayy too high ill throw a code
Old Nov 4, 2004 | 10:41 AM
LudeyKrus's Avatar
Make sure your sensor types are set to 6.
Old Nov 4, 2004 | 03:12 PM
Default Re: (LudeyKrus)
yeah they are at 6 in and 6 out
Old Nov 4, 2004 | 05:23 PM
@ries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superjunprelude &raquo;</TD></TR><TR><TD CLASS="quote">so youre saying if i set the fuel wayy too high ill throw a code</TD></TR></TABLE>yes.. and double check your wiring.
Old Nov 4, 2004 | 05:35 PM
mgags7's Avatar
this is from adding too much fuel.....the vafc is telling the computer that the map signal is getting into an unacceptable range by the ecu's standards....you need to pull some fuel out there....then it will work fine, your wiring should be ok
edit: dont play around adding fuel without a wideband...you will wash down the cylinder walls and ruin your rings....
Old Nov 4, 2004 | 05:39 PM
Default Re: (mgags7)
thank you very much peeps for helping me i will do that
South Bay Surfer
Dec 24, 2004 02:15 PM
citrus3000psi
Oct 21, 2003 03:50 PM
PrecisionH23a
Sep 17, 2002 10:24 AM
AfEn808
Jan 27, 2002 03:01 AM
