bellow boot
Old Nov 1, 2004 | 09:52 PM
esca's Avatar
Default bellow boot
i was wondering what a bellow boot was.. i went to wheel works or something.. and they said my bellow boot was torn, and it really doesnt affect driving, but i hear a constant knocking at low high gear rpms sometimes.. and was wondering if it could be the source of the problem..
Old Nov 2, 2004 | 04:19 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: bellow boot (esca)
Edit: I learn something new everyday.
Modified by Sticky Tires at 6:55 AM 11/3/2004
Old Nov 2, 2004 | 07:06 AM
si92hb's Avatar
Default Re: bellow boot (Sticky Tires)
Bellow boot is probably the boot on each end of the steering rack
I highly doubt it would cause your knocking...
Old Nov 2, 2004 | 07:09 AM
esca's Avatar
Default Re: bellow boot (si92hb)
its that.. compressible boot right? its ribbed kinda likea condom.. haha..
you sure it wont cause knocking? because like at high speeds and when im on the throttle (high gears low rpms) it makes a clicking sound.. close to knocking but like 2 parts arent fitted together very well sound...
Old Nov 2, 2004 | 08:23 AM
Elkins911's Avatar
are you turning or going straight?
Old Nov 2, 2004 | 10:04 AM
esca's Avatar
Default Re: bellow boot (Elkins911)
going straight at high speeds.. but when im taking like the twisties.. it kinda does it while im turning and in 3rd gear too
Old Nov 2, 2004 | 11:33 AM
T-Mo's Avatar
I am having the same problem. My bellow boot is torn and it makes clanking sounds too. The bellow boot is the rubber boot right where the tie rod end is: #13
Old Nov 2, 2004 | 01:26 PM
esca's Avatar
nicee... you know that **** costs 130 to fix..
im thinking about doing it myself.. but it seems like hella work and i just dont have the time to do it..
Old Nov 2, 2004 | 06:38 PM
si92hb's Avatar
ATTN: I speaking from the POV of a civic owner, that being said when I replaced my one boot I went ahead and replaced them both and both tie rod end ball joint boots, on my civic the drivers and passenger side boots are different as well as the clamps, so you may want to make sure your are getting the correct side. Hardest part of the job for me was just getting access to the clamps to secure them via bending the tabs on the clamps themselves.
Changing the |bellow boot (13)| is a DIY job, I had to buy the boot from a dealer so it cost me a little more but just buy the boot online, while you at it you will also need |clamp (11)|, and you may want to buy the |tie rod end ball joint boot (15 or 17)| because you have to remove the tie rod end to put the new bellow boot on and may end up damaging your current tie rod end ball joint boot in the removal process. You should be able to reuse your |spring clip (15)|.
Afterwards you are more than likely also going to need a wheel alignment.
Old Nov 2, 2004 | 08:25 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
yeah my bellow boots are torn too but no knocking...
Old Nov 3, 2004 | 12:33 PM
esca's Avatar
Default Re: bellow boot (PreIudeSI)
thanks for input
Dale_K
Oct 26, 2010 01:39 PM
fs909
Jan 5, 2010 07:32 PM
ludewithanh22
Feb 4, 2005 11:22 AM
ZetecOwns
10
Oct 5, 2002 08:03 AM
balistic CRX
Feb 7, 2002 11:31 AM
