emergency help!!!!!!!!!!
Old Nov 3, 2004 | 04:27 PM
kr3nse0ulja's Avatar
Default emergency help!!!!!!!!!!
i just recently got a used h23 for my 92 prelude that onli has 30k on it . i cant seem to know why its burning up my oil sooooo fast...i have to get a new oil change like every 2 weeks.....does anyone know why!... i jsut installed a new pvc that connects to tha fuel fuelter thiknin that was why...but i guesss not.....help me please wat could be tha problom to all this bull
Old Nov 3, 2004 | 04:30 PM
Hawkze_2.3's Avatar
Default Re: emergency help!!!!!!!!!! (kr3nse0ulja)
Whoahhhhh...Are you sure your PCV valve is connected to the fuel filter?? Try to post a pic of what you're talking about....
Old Nov 3, 2004 | 04:31 PM
Prolink's Avatar
Are you leaking any oil or can you smell oil burning?
Old Nov 3, 2004 | 04:38 PM
mgags7's Avatar
pvc to your fuel filter...hmm havent heard of plastic fuel filter piping yet but maybe its the newest thing....hmmm......
hmmm.....new engine/burning oil theory:
(gathered at the all mighty search page):
bad seals inside from sitting dry for too long......
either your burning or leaking....look under your car tommorrow morning and you will know if your leaking, look at your exhaust smoke when you start it and you will know if your burning....start it up and let it warm all the way, then give it a good rev, wait 10sec, then rev it again to like 4 or 5k...if it belches out white smoke your piston rings are shot....if not, then shut it off, let it sit for about 10 minutes, then start it again, if it puffs out white smoke when you start/the first time you rev some, then your valve stem seals are shot.....if it does either of these your new 30k engine is crap and you should look for another one....to fix either of these problems is gonna cost you big....for now try a slightly higher weight oil if your running 5w use 10w, that will stop some burning...but dont go any higher....
Old Nov 3, 2004 | 06:19 PM
BlissSkr's Avatar
u sure the engine has low miles? and who swapped the new engine in?
Old Nov 3, 2004 | 08:00 PM
vinuneuro's Avatar
Default Re: (mgags7)
Wrong man. White smoke indicates coolant being burnt. You wanna look for black/blue smoke.
swizz977
Sep 27, 2013 09:44 AM
zach53
Feb 28, 2012 03:05 PM
the ludee
Apr 7, 2008 05:22 PM
1991civicsi
Feb 6, 2006 04:04 PM
duggy
May 14, 2005 10:12 PM
