how EXACTLY does VTEC work???
Old Sep 26, 2006 | 06:01 PM
bluedlude's Avatar
Default how EXACTLY does VTEC work???
this is not a noob question! well i guess it KINDA is. from the activation on the VTEC solenoid to the rockers. I can't understand how the dowel in the rockers locks it into VTEC. I see a little oil passage that goes into the spring loaded rocker(idle rocker?) and then there is a floating dowel. i dont what the dowel is doing. i notice a little oil squirter on the (VTEC rocker?). what the hell is going on in there?
Old Sep 26, 2006 | 06:04 PM
M2B4's Avatar
Default Re: how EXACTLY does VTEC work??? (bluedlude)
http://www.youtube.com/watch?v...arch=
go there
Old Sep 26, 2006 | 06:08 PM
SOHC-VTEC-BB2's Avatar
Default Re: how EXACTLY does VTEC work??? (M2B4)
Honestly that didn't really answer his question.
Old Sep 26, 2006 | 06:23 PM
bluedlude's Avatar
Default Re: how EXACTLY does VTEC work??? (92Si4wsH22a4)
well, I figured it out. not from the video but from looking at the rockers again. so the oil comes in through the rocker shaft into the idle rocker. the hydraulic pressure pushes that piston out which in turn pushes the floating piston which pushes in the spring loaded piston lock into VTEC.
but at idle isnt there a difference in valve lift? the two outer lobes have different lift. how is that compensated for?
Old Sep 26, 2006 | 08:04 PM
Rosko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">well, I figured it out. not from the video but from looking at the rockers again. so the oil comes in through the rocker shaft into the idle rocker. the hydraulic pressure pushes that piston out which in turn pushes the floating piston which pushes in the spring loaded piston lock into VTEC.
but at idle isnt there a difference in valve lift? the two outer lobes have different lift. how is that compensated for?</TD></TR></TABLE>
what do you mean? thats what vtec is all about... dual cam profiles
Old Sep 26, 2006 | 08:20 PM
mgags7's Avatar
what do you mean how is that compensated for?? the cam lobes push the rockers just like in any other car....
Old Sep 27, 2006 | 04:03 AM
bluedlude's Avatar
Default Re: (bb4ever)
so do you not understand what im saying? when the Vtec isnt locked into place, the outer two rockers are riding the outer two cam profiles. well if the profiles are different(which they are) wont it make more lift on one compared to the other?
Old Sep 27, 2006 | 04:29 AM
Rosko's Avatar
Default Re: (bluedlude)
the outer two profiles are the same (low lift)
vtec is the middle rocker.
Old Sep 27, 2006 | 05:22 AM
bluedlude's Avatar
Default Re: (Rosko)
so you are telling me that the two outer lobes are the same?
and I just took this pic of my H22 cams.
Old Sep 27, 2006 | 05:38 AM
Mykizism's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">so you are telling me that the two outer lobes are the same?
and I just took this pic of my H22 cams.</TD></TR></TABLE>
no they are not the same..
primary and secondary lobes are different height to allows one valve to open more than the other to promote swirl and have a better / cleaner combust out of vtec..
middle lobe is vtec lobe for HUGE and equal valve lift
Old Sep 27, 2006 | 05:46 AM
bluedlude's Avatar
Default Re: (Mykizism)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism &raquo;</TD></TR><TR><TD CLASS="quote">
middle lobe is vtec lobe for HUGE and equal valve lift</TD></TR></TABLE>
thank you so much!!
Old Sep 27, 2006 | 06:30 AM
flyrod's Avatar
There are different types of vtec, and they way they "exactly" work is a little different depending... Check this out:
http://www.leecao.com/honda/vtec/index.html
Old Sep 27, 2006 | 08:16 AM
bluedlude's Avatar
Default Re: (flyrod)
well I was mainly talking about the H22 vtec.
Old Sep 27, 2006 | 08:47 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">so do you not understand what im saying? when the Vtec isnt locked into place, the outer two rockers are riding the outer two cam profiles. well if the profiles are different(which they are) wont it make more lift on one compared to the other?</TD></TR></TABLE>
yes it does, this is the same concept of primary and secondary camshaft lobes that has been running 4 valve motors forever....
theyre not the same profile at all, but that doesn't have anything to do with vtec....
Old Sep 27, 2006 | 08:53 AM
Mykizism's Avatar
vtec is for noobs.. real power is made by big Turbos
Old Sep 27, 2006 | 09:17 AM
bluedlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">
theyre not the same profile at all, but that doesn't have anything to do with vtec....</TD></TR></TABLE>
yeah, i already got it from
thanks for the help everyone
Old Sep 27, 2006 | 12:50 PM
Rosko's Avatar
damn, I never even noticed that. I just grabbed a cam and its pretty obvious.
does the whole swirl thing only apply to the lower rpm range? I'm guessing once in the upper rpm's hit it would have less of an effect?
Old Sep 27, 2006 | 01:11 PM
AnthonyG2003
Guest
Posts: n/a
my vtec goes wheee wheeee WHEEEEEEEEEEEEEEE!
Old Sep 27, 2006 | 05:01 PM
DfwBB6's Avatar
Default Re: how EXACTLY does VTEC work??? (AnthonyG2003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthonyG2003 &raquo;</TD></TR><TR><TD CLASS="quote">my vtec goes wheee wheeee WHEEEEEEEEEEEEEEE!</TD></TR></TABLE>
widewhite
Feb 13, 2015 06:11 AM
blacktibby07
May 14, 2011 11:12 AM
junk95civ
25
Jan 29, 2010 12:09 PM
GiT LaO'd
Nov 22, 2004 04:24 AM
Nsane1
Jun 12, 2004 04:47 PM
