Not sure which NGK Spark Plugs to pick up for my 97
dotmichael to you
-NGK Laser Platinum Spark Plugs, part# PZFR6F-11 - $11.00 each
-NGK Copper Spark Plugs, part# ZFR6F-11 - $2.50 each
-NGK Iridium IX Spark Plugs, part# ZFR6FIX-11 - $6.95 each
These are the three plugs for a USDM H22a4. Car is just about stock with I/H/E
I know the laser platinums are what come from factory. I dont want crap in my car and I'm even going to have it up for sale soon (However, in no rush at all so I will happily continue driving it) so I'm not sure whether I need to get those $11 a piece plugs.
Alternatively, the coppers are for my car...but i'm curious as to whether or not there will be a difference in terms of performance. (in terms of optimum spark and starting my car without a problem, not horsepower)
In case it matters, I'm simply changing these (along with my plug wires) for a tuneup.
Also, if you know of a place that I can pick up any of those for cheaper, I'm all ears.
Re: Not sure which NGK Spark Plugs to pick up for my 97 (MadCityLude)
I just bought some Iridium for my car about 2 weeks ago. No problems at all.
Before i bought my set i did some searching the iridiums were the most popular choice just a FYI.
Re: Not sure which NGK Spark Plugs to pick up for my 97 (Pilky)
i put platinums in because they're standard equipment, i wouldn't bother with copper plugs, just pay the extra and get platinums. iridiums are more expensive i think but its a waste of money, i've never heard of someone gaining power by using iridium plugs over stock platinums one's
Re: Not sure which NGK Spark Plugs to pick up for my 97 (pizzamanprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pizzamanprelude »</TD></TR><TR><TD CLASS="quote">i put platinums in because they're standard equipment, i wouldn't bother with copper plugs, just pay the extra and get platinums. iridiums are more expensive i think but its a waste of money, i've never heard of someone gaining power by using iridium plugs over stock platinums one's</TD></TR></TABLE>
According to the prices above, the iridiums are cheaper!
Re: Not sure which NGK Spark Plugs to pick up for my 97 (rocket30004)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude »</TD></TR><TR><TD CLASS="quote">I always buy NGK Iridium. But really its up to you I think. Everyone will have there opinions and they will vary,</TD></TR></TABLE>
im ngk iridiums also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocket30004 »</TD></TR><TR><TD CLASS="quote">
According to the prices above, the iridiums are cheaper! </TD></TR></TABLE>
in the UK those iridiums are real expensive, i bought my platinums for £32 for four, the iridiums were over £40
i just buy the V powers. They are 2 dollars or so a pop. If you are bored and want to blow 50 bucks on iridium plugs, go for it.
Re: (bb4ever)
Copper conducts electricity better than platinum so u copper has a performance edge but the platnium last a lot longer. So its ur choice....performance vs. life(dont know anything about the Iridium plugs)
dotmichael to you
Re: (pizzamanprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH »</TD></TR><TR><TD CLASS="quote">i just buy the V powers. They are 2 dollars or so a pop. If you are bored and want to blow 50 bucks on iridium plugs, go for it.</TD></TR></TABLE>
Part number?
Part number?
Re: (. M i c h a e l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . M i c h a e l »</TD></TR><TR><TD CLASS="quote">
Part number?
These are the V-Powers
Part number?
i like denso irridum.......
my butt dyno noticed a diff over stock, but it could have been over correction from my brain dyno....
Modified by 92blkJDMh22 at 1:49 PM 9/21/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pizzamanprelude »</TD></TR><TR><TD CLASS="quote">copper conducts better than platinum? thats amazing</TD></TR></TABLE>
yes it does....i just searched the net right now and came with a few results just click, scroll down, and read
http://64.233.161.104/search?q...fox-a
http://64.233.161.104/search?q...ox-av
Re: (hamadiscool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamadiscool »</TD></TR><TR><TD CLASS="quote">
http://64.233.161.104/search?q...ox-av </TD></TR></TABLE>
by glancing tru it looks like copper conducts better but im in that decidion now too of getting new plugs and had question about it cuz i was thinking to get the NGK Iridium IX Spark Plugs
Re: (hamadiscool)
you didn't understand my sarcasm, i said its amazing because platinum isn't used in sparkplugs because of conductivity, neither is iridium, they're used because performance plugs have fine wire electrodes for better spark propagation and copper would fall apart if it were that fine.
Guest
Posts: n/a
Re: (hamadiscool)
YEP! V POWER ALL THE WAY! UNLESS YOU HAVE AN NSX OR SKYLINE...HIGH "PERFORMANCE" SPARK PLUGS DON'T DO ANY GOOD.
WITH COLD/HOT PLUGS/ IRIDIUM/ PLATINUMS... IT MAY NOT EVEN GAIN YOU ANY POWER AND CAN EVEN BE USELESS AND LESS EFFICIENT THAN OEM . V-POWERS!
EXPENSIVE SPARKS FOR LOW PERFORMANCE HONDAS:
V-POWERS WITH NGK WIRES :
Re: (preludebbduce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludebbduce »</TD></TR><TR><TD CLASS="quote">YEP! V POWER ALL THE WAY! UNLESS YOU HAVE AN NSX OR SKYLINE...HIGH "PERFORMANCE" SPARK PLUGS DON'T DO ANY GOOD.
V-POWERS WITH NGK WIRES : </TD></TR></TABLE>
go away, youre a retard
having a more powerful car has nothing to do with needing plugs that last longer, the only reason platinum and iridium plugs are reccomended is because they last the OEM service interval....
Re: (preludebbduce)
how is using a platinum plug going to be less efficient than OE plugs if OE plugs are laser platinum. and you wont gain power with any sparkplug, you'll only lose it by selecting the wrong one. and stop using capitals you d!ck
dotmichael to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmayhew »</TD></TR><TR><TD CLASS="quote">i think NGK laser platinums are reccomended...they are the pricy $10-$12 ones</TD></TR></TABLE>
not according to this thread.
dotmichael to you
Re: (The Phil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Phil »</TD></TR><TR><TD CLASS="quote">Get the $2.50 ones. The others just last a bit longer, not worth it IMO.</TD></TR></TABLE>
Yeah, just placed my order.
