Help Installing external fuel pump
Old Sep 27, 2006 | 01:56 PM
TopEndUSA's Avatar
Default Help Installing external fuel pump
Can someone send me pics or directions on installing a external fuel pump. I believe I can run the feed lines, but what about the return. How do you do it? I plan on just using the drain plug for the feed. What do you guys suggest. Thanks
Old Sep 29, 2006 | 05:33 PM
AMS MIKE's Avatar
Default Re: Help Installing external fuel pump (MardreRacing)
cut a hole in the center of the rear of the gas tank and either have a sump made or buy one off full-race.com or summitt racing and weld it on with the correct fittings. Then run a prefilter (60 microns) and then your pump.
fwalcom
18
Mar 21, 2007 10:09 AM
DaveF
Oct 20, 2005 09:16 AM
EGJDM
Sep 21, 2004 07:02 PM
StupidSlowRSX
10
May 3, 2004 02:34 PM
GSR_Hacker
Jul 8, 2002 06:50 PM
