anyone have a p13 basemap?? cant find any that work
every basemap i download has a duty cycle of 24% at wot and 7500rpms. has anyone else experienced this? does anyone have another one they could post? thanks for any help.
send it to joshpntbl@aol.com, feel really dumb asking this but, how the heck do you send a pm? thanks
moderator emeritus
Re: anyone have a p13 basemap?? cant find any that work (tegman85)
p13 basemaps only have the ignition values. The formulation for fuel has not been discovered yet.
found answer to my own question. you can take a p28, burn a basemap for a gsr(probably others), then copy the ignition maps from a p13 basemap, then just tune the fuel the way you want it. only thing is, p28 basemap doesnt allow you to set when your iab's open.
Re: (tegman85)
read the post below to see a little mod to get your IAB to be controlled by VTEC, I did the mod and it is working great with my new chipped P28 ECU.
https://honda-tech.com/zerothread/1681226
Re: (tegman85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_VTEC_lude »</TD></TR><TR><TD CLASS="quote">read the post below to see a little mod to get your IAB to be controlled by VTEC, I did the mod and it is working great with my new chipped P28 ECU.
https://honda-tech.com/zerothread/1681226</TD></TR></TABLE>
theres another way to do it.
you have to open the ECU and mod it for IAB. Its pretty simple, i did it and it worked fine.
here found the how to for you.
http://www.pgmfi.org/twiki/bin...ToP28
i was just thinking, and why cant you just copy the fuel maps from the p30 or p72(heard both would work) into the p13 basemap, then you'll have the ignition maps and be able to tune iab. would this work? thanks
Re: (tegman85)
the P28 doesnt have the ability to tune IABs without modding the ECU. the P72 has IAB control. you can copy any values to anywhere, its just a spreadsheet, but opening IABs has nothing to due with adding the timing and fuel values to your basemap.
chris89
Engine Management and Tuning
11-17-2015 05:47 AM
mouab18c1
14
10-18-2013 11:44 AM
