h22a4 fit in 96 prelude?
Old 09-26-2006, 07:38 AM
drumminforev's Avatar
Default h22a4 fit in 96 prelude?
I have us spec h22a4 non sh, wondering if it will fit in place of an h22a1 for a 1996 prelude. any special mounts needed?
Old 09-26-2006, 07:44 AM
Finest's Avatar
Default Re: h22a4 fit in 96 prelude? (drumminforev)
Complete bolt in. It's the same block, externally.
The only thing to watch out for:
1) Use your old wiring harness.
2) Use your a1 distributor, external coil, fuel rail and injectors.
3) You do not need to hook up the CKP sensor on the a4, which is located in the lower rear of the block. The a1 distributor has the CKP sensor built in.
Everything else is bolt in. (I put an a4 in my 95 Si)
Old 09-26-2006, 07:48 AM
Default Re: h22a4 fit in 96 prelude? (Finest)
my h22a4 is the external coil distributor, so would that work, or is it still better to use that a1
and that made me think....what if you have adjustable cam gears, how would the ckp sensor still be accurate?
Old 09-26-2006, 07:59 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev &raquo;</TD></TR><TR><TD CLASS="quote">my h22a4 is the external coil distributor, so would that work, or is it still better to use that a1
and that made me think....what if you have adjustable cam gears, how would the ckp sensor still be accurate?</TD></TR></TABLE>
I don't know if there's a difference between the a4's or a1's external coil, but to be safe reuse the a1 coil.
The CKP sensor is on the distributor, so it'll pick up off the exhaust cam.
Old 09-26-2006, 08:04 AM
Yes, but if you have adjustable cam gears and you move the cam a few degrees out, that would make the sensor inaccurate wouldnt it?
Old 09-26-2006, 08:40 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but if you have adjustable cam gears and you move the cam a few degrees out, that would make the sensor inaccurate wouldnt it?</TD></TR></TABLE>
Good question.
I don't have adjustable camgears, so I haven't had any problems with my swap.
Old 09-26-2006, 09:41 AM
bump for an answer, about CKP on adjustable camgears
Old 09-26-2006, 10:05 AM
darkspector2.0's Avatar
Haven't people with a1's put adjustable cam gears on there before? wouldn't it be the same thing
Old 09-27-2006, 01:04 PM
Default Re: (darkspector2.0)
Im not sure what you are saying, im wondering if it would throw the sensor off
Old 09-27-2006, 11:00 PM
someone just answer this last question
Old 09-27-2006, 11:07 PM
Hawkze_2.3's Avatar
Why would it not mess up the sensor? Seems like you would have to move the sensor along with the cam & gear to keep things right.
Rotting Prelude
11-24-2017 05:32 AM
JDMJUMA
10-15-2017 12:27 AM
BeE_B4
08-07-2006 09:41 PM
gtpilot
01-06-2003 08:33 AM
3gLudeH22A
03-03-2002 05:37 AM
Quick Reply: h22a4 fit in 96 prelude?
