building a head....
Old Sep 25, 2006 | 06:12 PM
bluedlude's Avatar
Default building a head....
so im building up an H22 head for myself. well im planning on getting type S cams and I know that there is a possible clearance issue that I would rather avoid. well if i use only the RM retainers and stock springs, wont that be good enough?
Old Sep 25, 2006 | 07:09 PM
98vtec's Avatar
moderator emeritus
Default Re: building a head.... (bluedlude)
i dont believe rocket will sell his retainers seperate from the valvesprings.....i think i remember reading that.
why not get his retainers and valvesprings?
Old Sep 25, 2006 | 07:31 PM
Attaus's Avatar
The retainers are all you need, but go the extra mile.
Old Sep 25, 2006 | 07:52 PM
bluedlude's Avatar
Default Re: building a head.... (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">i dont believe rocket will sell his retainers seperate from the valvesprings.....i think i remember reading that.
why not get his retainers and valvesprings?</TD></TR></TABLE>
I most likely would have anyway, unless someone really tried to talk me out of it.
Old Sep 27, 2006 | 11:25 AM
alterdcreations's Avatar
I really dont think it the type-s cams
https://honda-tech.com/zerothread/1763499
it happens to factory and abouts all of the aftermarket cams.
maybe it the valve lash
https://honda-tech.com/zerothread/1671032
check out both links.
their doesn't seem to be a clear answer.
I know their are people running them in their car with out problems.
crower say that the problem happens at .490 degrees of lift.
type-s cams only have 473(dont qoute me on any of the numbers)
but the type-s cam doesn't reach the required lift to cause interfearnce.
maybe its coil bind or not properly setting the valve lash.
very rare either way.
Old Sep 27, 2006 | 11:46 AM
bluedlude's Avatar
Default Re: building a head.... (alterdcreations)
yeah, ive never gotten a clear cut answer on it, but ive also never heard of anyone have to modify the guides and seats for any high lift cam. maybe people just dont talk about it? crower and RM are the only companies that have the higher clearance that I know of. so if there was a problem wouldn't it be well known?
Old Sep 27, 2006 | 12:04 PM
If you look on crower website they tell you the specs of all factoy h22a cams
http://crower.com/cat/import/honda/cams/h22.shtml
they say the interference happens at a certin amount of lift
clearly the lift of the type-s cams is not enough for this to happen
Old Sep 29, 2006 | 04:27 PM
I called Dusty or Danny(i forgot) at crower and he said that it wouldn't need retainers to clear the guide. Notice none of the cars burned any oil or had any noticeable problems. its got to be coil bine. an another note he said that he could could make custom cams for the h22 for $550. like 496 Gross Lift w/1.55 and what ever duration you can build your bottom end to. say 9500 rpms,if you dare
Old Sep 29, 2006 | 05:12 PM
i think i might try
Old Sep 30, 2006 | 04:53 AM
bluedlude's Avatar
yeah well, bottom end will be lacking becasue i want to keep it streetable. ive got a brnad new set of type S pistons ready to go. and it pointless to get too much duration without raising the compression way up. in my opinion.
Old Sep 30, 2006 | 05:51 AM
true. but thats the beauty of vtec. maybe stage 3 h23 #1 lobe, h23 stage #2 lobe for non vtec lobes and custom grind crower any spec that i want on the vtec lobes still for $550. thats custom and cheaper than alot of cams on the market and + you get what you need per indivual motor
im going to try it.
explain
Modified by alterdcreations at 10:27 AM 9/30/2006
Twolowpaco
May 22, 2007 05:55 PM
Teamdiesel
11
Mar 19, 2007 08:19 PM
Black R
Jun 5, 2005 01:06 AM
b18builder
Feb 14, 2005 07:59 AM
es_squared
Nov 25, 2004 02:35 PM
