H22 isn't so enjoyable hot...
The car: 1992 Prelude SI (h23)
The motor: JDM H22 from hmotorsonline.com
The swap went easily except for the external/internal coil nonesense. Then the car start to have a HARDCORE sputtering issue. anything more than 45% throttle at or above 3300rpm wouldn't happen. so much sputtering that i could've sworn i was on a bucking bronco. Another problem was it wouldn't start if it sat in the sun through the day (park it at night, try and drive it after 9 or 10 am -- when the car gets warm form the sun). If i park it in the garage, or under a large shade tree, i can start it.
so i got a new distributor, knock sensor, changed all fluids etc. Works perfectly. and drives like a beast. But the heat problem still remains.
CLIFF NOTES:
[/b]IF THE CAR SITS IN THE SUN, IT WONT START[b]
Anyone have this problem or have any clue as to what this can be? its not the battery as the car will crank over till the cows come home, starter is about 4 years old and still works GREAT... fuel pump issues maybe?
CLIFF NOTES:
Re: H22 isn't so enjoyable hot... (LudeFanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeFanatic »</TD></TR><TR><TD CLASS="quote">Main Relay, do a search.</TD></TR></TABLE>
+1
+1
Re: H22 isn't so enjoyable hot... (99LudeDude)
+2
+2
also check any and all ignition related wires.
its the main relay, under heat, things expand, and those soldiers are not making good connection, either fix them or get a new one, problem fixed...
like has been said WAY too many times on here lately....
Re: (Mykizism)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism »</TD></TR><TR><TD CLASS="quote">check the plasma conduits.. or bypass the anti matter relays</TD></TR></TABLE>
ahh **** youre right, and there i was taking an oscilloscope to the flux capacitor....geez
Re: H22 isn't so enjoyable hot... (beqa16v)
glad im an object of humor sorry, i was way drunk/lazy at 10 when i wrote that. sorrrrrrrrrrryyyyyy
but thank you guys for answering
exratedaccord93
01-26-2007 01:25 PM
