98 prelude that sounds like a WRX with An exhaust on it
Timing is on new wires,plugs ect. sent head 2 get deck and valvle put in. 2 months ago i burned a huge hole through my exhaust valve . comp test 175 in 3 cyl 200 in number 2 dont ask me y 200 in #2. The only thing that i have internaly is type s pistons
Car sounds great at idle soon as you hit the gas it sound like a Wrx
Any ideas what the promblem is
Re: (Slow_BB6)
Could be the dizzy starting to go......Are you by any chance getting a little squeal when you start the car?
I just had this similar issue last week but it ended up being a bad spark plug wire....
You may want to check that also....just because theyre NEW doesn't mean they are perfect.....Especially if the box they came in says MADE IN USA.
do a power balance test.
ground out each spark plug wire. if you ground it out, there should be a noticeable drop in rpm. if you ground one out and there is no rpm drop, that cylinder is misfiring. if you find that one is misfiring. find the reason why. check compression again. check plugs, wires, etc.
zerovandez
01-23-2014 06:53 AM
Chipped B6
02-25-2009 05:58 PM
dohcter g
03-23-2004 08:16 AM
