ok wtf
Old Jun 27, 2008 | 07:30 PM
SLOSI7's Avatar
Default ok wtf
i was driving one day and my 1992 prelude si w/ a h23 suttered and died so i changed the fuel pump cuz i couldnt hear it priming and nothing changed so i figured main relay, bought a new oneand still nothing. so i checked for spark..ya i know a little late. but i wasnt getting anything out of the distributor but i was from the ignition coil so i bought a new disributor and still not getting spark out of it. so im completly confused right now. but also the radiator broke while towing it after it died so right now there is no radiator in it but idk if that has anything to do w/ not getting spark but if anyone has an answer that would be awsome.
Old Jun 27, 2008 | 08:14 PM
High Reved Racing's Avatar
Default Re: ok wtf (SLOSI7)
check your ground strap
Old Jun 27, 2008 | 08:17 PM
thao0094's Avatar
does it at least crank?
Old Jun 29, 2008 | 06:05 PM
SLOSI7's Avatar
Default Re: (thao0094)
ya it trys to crank but doesnt start and a ground strap from wat?
Old Jun 29, 2008 | 06:08 PM
Hawkze_2.3's Avatar
Default Re: (SLOSI7)
So you get spark form the coil but not the distributor? That would mean your new distributor is not working... Did you get an OEM Honda distributor? Any check engine lights?
Old Jun 29, 2008 | 06:25 PM
SLOSI7's Avatar
Default Re: (Hawkze_2.3)
the check engine light does not come on when the ignition is at on like all other cars i have tried
Old Jun 29, 2008 | 06:34 PM
Hawkze_2.3's Avatar
If the light NEVER comes on then the bulb is burnt out or you have a bad ECU.
Old Jun 30, 2008 | 01:05 PM
UK_Luder's Avatar
Can you still not hear the fuel pump priming
Old Jun 30, 2008 | 01:41 PM
Saosinx's Avatar
Default Re: (UK_Luder)
check the ground going to the thermostat?
Thecargoddess
Jul 3, 2024 07:09 PM
Kris's turbo
Oct 11, 2011 10:05 AM
hksracing
Oct 17, 2008 12:46 PM
erik92DA
Jun 8, 2006 08:16 PM
GQ Cowboy
Dec 14, 2003 09:55 PM
