1999 Honda prelude H22a4 wont start
i cant get my car to start, i am getting plenty of fuel but no spark from the plugs or the coil directly.
there is no spark coming from the external coil, so makes me believe there is either a: a grounding issue or b: bad CPK/TDC sensor at the oil pump.
let me give you a quick run down:
i have plenty of fuel, in each cylinder
no sparks in any cylinder via plugs
no spark from coil
timing at the cams and fly wheel meet at TDC on the spot
checked grounds, (but will check again when i get home)
it doesnt make sense.. the car ran fine, idled great like a month ago before i made my new exhaust..
so yeah... im running on very little sleep, stayed up all night till the sun came out trying to get my car running..
so any ideas would be greatly appreciated
no spark from coil
Re: 1999 Honda prelude H22a4 wont start (Mykizism)
There's a procedure in the helms to test the coil. Is the coil receiving power? Those are good places to start.
Re: (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker »</TD></TR><TR><TD CLASS="quote">Fuses?
Are you sure the coil is good.</TD></TR></TABLE>
yeah i check all the fuses
i have two coils, as far as i know they both work and still very new. i have a friend with a prelude coming over tonight to test my dist, and coils on his car to verify they work
but i will also do the helms test.. that vinuneuro reccomended as well
keep em' coming guys anything right now would help maybe im overlooking something very stupid..
moderator emeritus
Re: 1999 Honda prelude H22a4 wont start (DfwBB6)
coiled plugged in?
make sure the ground on the thermostat has good contact.
I find it weird that the coil is not firing even after replacing it. How did you test the coil?
take the coil wire off the distributor and place it just close enough to its prong to see the spark arch from the coil wire to the distrubutor prong. If it sparks, move to the distributor/ICM.
if you had a problem with the CYP/CKP then you would be getting a check engine light.
got the car to start, friend came over we swapped dists..
mine is bad, his is good..
my car starts now though.. well at least i know what the issue is
its probably something inside it
Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">you can thank me later </TD></TR></TABLE>
the exhaust i think covers it
for future references it was the ICM guys.. thanks for all the input and ideas
i just didnt assume it was the ICM bc the dist is still practially brand new.. haha.. and i barely drive the car
but oh wells!
but oh wells!
Re: (Mykizism)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism »</TD></TR><TR><TD CLASS="quote">
but oh wells!
Told ya, i have had that same problem replaced it and boom car starts and u can thank me with an exhaust too! 3in all the way plz
but oh wells!
Re: (hondatunedbboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatunedbboy »</TD></TR><TR><TD CLASS="quote">Glad everything is back in working order </TD></TR></TABLE>
thanks for coming over and letting me test ur **** out.. even tho it was dirty! hahaha
Robert Gussler
08-02-2012 08:41 AM
