Idle problem
Old Jun 29, 2008 | 08:28 PM
TheOdd001's Avatar
Default Idle problem
When I start my H23 cold, it idles at 3k! As it warms up it drops down to 2k... I cleaned the IACV, didn't help at all. When I unplug the 2P connection at the IACV it drops to 1200 rpm and bounces up and down at idle. I tried the idle adjust screw but idle doesn't move at all with the screw in full left or right positions. I don't seem to have any vacuum leaks either. Can any one help? I have a 93 prelude Si
Thanx...
Old Jun 29, 2008 | 08:50 PM
Hawkze_2.3's Avatar
Default Re: Idle problem (TheOdd001)
You probably need to adjust your FITV (fast idle thermo valve). It makes your car idle high until it reaches a certain temp, and it sounds like your may just need adjustment.
Also, if it stays at 2K once it's warmed up, then you have a vacuum leak somewhere. Vacuum line or a gasket most likely.
Old Jun 29, 2008 | 09:57 PM
High Reved Racing's Avatar
Default Re: Idle problem (Hawkze_2.3)
X2
Old Jun 29, 2008 | 09:58 PM
Default Re: Idle problem (High Reved Racing)
had the same prob on mine just fixed it today
Old Jun 29, 2008 | 09:59 PM
94vtirozguy's Avatar
you could also have a leak
Old Jun 29, 2008 | 11:26 PM
TheOdd001's Avatar
Default Re: (94vtirozguy)
How is the FITV adjusted?
Old Jul 7, 2008 | 07:32 AM
TheOdd001's Avatar
Default Re: (TheOdd001)
It was the FITV! I cleaned it and screwed in the plastic thingy now it runs great!!!
dc4b20
22
Dec 3, 2012 09:54 PM
b20eg9daddy
Oct 25, 2008 12:37 PM
Pele
Feb 9, 2003 01:01 AM
