how to install timing belt on h22
Re: how to install timing belt on h22 (SonicRacing)
1. unplug battery
2. Remove crank pulley bolt
3. Remove Crank Pulley
3. Remove Driverside motor mount.
4. Remove outer t belt covers top and bottom.
5. Remove valve cover
6. Remove balancer belt assembly.
7. Remove Balancer belt tensinor
8. Remove timing belt
9. Remove Auto tensoinor(replace with manual tensinor.
10. Set all gears to TDC for Tbelt, oil pump, water pump, crank gear, Cam gears
11. Reinstall tensinors and belt
12. Reinstall Balancer belt assembly to TDC as well.
13. Reinstaill everything else
Civic4ever
10-07-2004 10:08 AM
belt, belts, change, h22, h22a, honda, howa, install, installation, installing, instruction, instructions, prelude, remove, timing
