1990 rough idle start up
Old 10-22-2014, 05:01 PM
bigturner87's Avatar
Default 1990 rough idle start up
I have a 1990 prelude si 2.1. When I start it up it will run rough like it is loaded up with fuel. I've cleaned the egr valve and the throttle body. It has a new TPS and its adjusted right .5 at closed and 4.5 wot. I ordered a new timing light so I can check that. Also it has new plugs ,wires, cap and button. Anyone with ideals please help me out. No check engine light on either.
Old 10-22-2014, 09:26 PM
holmesnmanny's Avatar
Does it only do it when the car is warmed up ?
Old 10-31-2014, 06:22 AM
motoxxxman's Avatar
Default Re: 1990 rough idle start up
any idea when it last had a valve lash adjustment?
have you done a compression test or leakdown test? cold, and hot
Old 11-08-2014, 10:09 AM
yungmulacrx's Avatar
X2 on valve lash..
egvr4
01-28-2013 07:41 AM
allmotorgsrekk
16
03-27-2010 07:30 PM
FBPPrelude
12-27-2006 07:12 PM
boonacka
10-08-2002 07:47 AM
ILOVEGIRLS
07-31-2002 02:43 PM
Quick Reply: 1990 rough idle start up
