I need help
Old Nov 13, 2014 | 05:37 PM
jarred1414's Avatar
Default I need help
1988 honda prelude 2.0 si 4ws. Driving the otherday and my belt broke off. Was told its my serpentine belt. Goes around the top pulley. A/c pulley and 2 more. How do I release the tension to get new belt on? I found the tensioner bolt and loosened it but still wont fit. Do I have to also loosen the bolt on the pulley? If so what pulley the one in the middle?
Old Nov 13, 2014 | 05:44 PM
holmesnmanny's Avatar
You have a power steering pump belt on top and an ac/alternator belt on the bottom.
You need to loosen up about a couple turns the two mounting bolts that run side to side. Then loosen the adjusting bolt until the pump starts slowly going down. The adjusting bolt will probably be a 10 mm and one mounting bolt will probably be 14mm and the other a 12mm.
Then slide the belt on and tighten the adjusting bolt. On the longest side of the belt, in the middle, you twist the belt with your fingers and you want about 90 degrees of deflection.
Old Nov 13, 2014 | 06:17 PM
jarred1414's Avatar
Default Re: I need help
The mounting bolts on the top pulley? I was assuming the top pulley was my ac. So its my power steering pump?
Old Nov 13, 2014 | 07:22 PM
http://www.hondapartscheap.com/auto-...ed-sensor-scat
It sits on top. Dont touch the pulley bolt.
41 is one mounting bolt. There should be a nut that you need to loosen and then you loosen the adjusting bolt.
Old Nov 14, 2014 | 10:27 AM
jarred1414's Avatar
I got it. Thanks for your help bro. Helped me more than you know. Thanks again
-InteGSR-
Feb 2, 2010 06:39 PM
jcinwelland
Mar 4, 2009 09:42 PM
vinuneuro
Oct 5, 2007 12:23 AM
wizzards581
Dec 7, 2002 01:37 PM
satan_srv
Aug 27, 2002 01:21 PM
