car goes into gear but wont move - Honda-Tech - Honda Forum Discussion
Old 11-17-2014, 11:22 AM
Default car goes into gear but wont move
1988 honda prelude 2.0 si driving down the street car wont move goes into gear but wont move. Help please
jarred1414 is offline
Old 11-17-2014, 12:41 PM
If your car is going down the street, then technically its moving.
You need to give out more detailed information about whats going on.
holmesnmanny is offline
Old 11-17-2014, 12:55 PM
Default Re: car goes into gear but wont move
Was jist driving down the street about ten miles car was perfect. Got to a stop sign and it just wouldnt go anywhere. Goes into gear but wont move. Let the clutch out all the way and car dont die or turn off. Starts right up but when put it in gear and let go of clutch give it gas and nothing. Wont move. Leaking something I noticed. Driver side axel looks wet. But bad axel it should still move right?
Old 11-17-2014, 01:01 PM
Moderator
crazes's Avatar
does your rpm rises when your in gear?
crazes is offline
Old 11-17-2014, 01:09 PM
Yes rpms rise when give it gas. Got it in first gear let clutch all the way out and give it gas. Rmps just go up. Car dont move
Old 11-17-2014, 03:48 PM
CD8
CD8's Avatar
Sounds like clutch went out, or broken intermediate shaft. I broke intermediate shaft off inside of diff before, and it did exactly as you describe. I thought the diff went out, was ready to pony up 1000 for a used h22 trans to get me home, but upon disassembly, discovered the intermediate shaft broke off insde diff... 250 was much nicer than 1000.
CD8 is offline
Old 11-17-2014, 03:58 PM
longest project ever
lostforawhile's Avatar
Location: on the south side of dixie, 1986 Accord Hatch
it popped out of the transmission, you need a new circlip, on the CV axle, it will pop out just a little on these transmissions and the car won't move, check your motor mounts too, bad mounts or suspension issues can cause it to pull out
lostforawhile is offline
Old 11-17-2014, 04:00 PM
the car won't move with a bad axle either, standard differential
Old 11-17-2014, 04:57 PM
Yea im tripping out. Had someone tell me to jack car up put it in 1st gear and see if the tire turns. And it does. Spin it with my hand. Car goes into any gear without pushing the clutch in. Confused. Dont even know where to really start. Want to elimainate stuff
Old 11-17-2014, 06:13 PM
READ my post, look at the end of the cv joint where it goes into the transmission, if there is oil leaking out, it's popped out a little, push it back in see if it clicks. This has happened to nearly every third generation Accord/2nd generation Lude owner who has owned their car long enough, don't be running the car in gear with it jacked up, you will screw the splines in the differential if the axle splines are barely making contact
Old 11-20-2014, 09:24 AM
Think I found the problem is there anyway to post picture up on here? I found something that looks wrong but it goes from back to front. Not side to side. Dont think its a axel. Or someone shoot me your phone number so I can text you pick please. I need some help dont know much about cars. Took a picture of something that looks wrong. Help
Old 11-21-2014, 02:56 PM
use imagur upload your pictures post the IMG link here,are you referring to the shift rod or the torque rod attached to the transmission?
Old 11-24-2014, 10:47 AM
What I was looking at I think is for my 4 wheel steering. But still cant figure out my problem. Gonna have to take it to shop I think. Just dont see how it could go from driving perfect to not driving at all.
Old 11-24-2014, 12:30 PM
andoxviii's Avatar
Can you actually FEEL the gear engage through the shifter?
Possible that the shift linkage bolt gave way and you actually aren't selecting a gear at all. It would act as if it was in Neutral.
andoxviii is offline
Old 11-24-2014, 04:14 PM
That sounds about right cause no I cant feel it engage through the shifter. How do I go about checking it?
Old 11-24-2014, 08:27 PM
If there is no resistance then obviously the linkage is suspect. First look at the top of the tranny. There will be your two linkage cables attached to the tranny with a cotter pin holding each cable on. See if the cotter pins are still holding the two cables to the tranny. Obviously they should also both move the gear selectors when you throw it into each gear.
Old 11-26-2014, 09:45 AM
I see what your talking about. It has both pins in it still. Both of lever move when put it through the gears. And the clutch one thats connected to tranny moves to when I push clutch in. Confused
Old 11-26-2014, 10:44 AM
Its possible the pressure plate went out and isnt holding the disk to the flywheel anymore.
Old 11-26-2014, 11:23 AM
StreetRacinThug's Avatar
Axle popped out
StreetRacinThug is offline
Old 11-26-2014, 02:33 PM
something gnarly
5SpdH22's Avatar
jack up the entire front of the car and see if the left wheel spins when you turn the right by hand, or vice versa. (don't worry if it's spinning the opposite direction)
5SpdH22 is online now
Old 11-28-2014, 10:08 AM
Turn the right wheel? Driver side?
Old 11-28-2014, 11:39 AM
Did it jacked car up spinned the tire other one dont turn. Did both tires and it dont move other one. Just went under car looks like axel poped oit. But at the second boot. Dont look like its oit where it connects to the transmission.
Old 07-18-2017, 09:47 AM
I'm having the same problem with my b16 lsd. If I put it in gear and spin a tire the other doesn't move. In gear clutch out car doesn't move but speedometer and Rpms do. both axles look fine unless they broke off into the trans?
boostedblue23 is offline
Old 07-20-2017, 05:50 AM
Moderator
snobordboy's Avatar
If your speedo is rising with the rpm, it means that your transmission is spinning. Sounds like you either popped axles out of the diff, or broke the axle/s right at the diff. Very common.
snobordboy is offline
Old 07-20-2017, 06:00 AM
I pulled both axles off and looked. Splines looked good and inside the diff looked good. Should I buy axles and replace them anyway maybe give that a try? Also I couldn't get my halfshaft separated from the axle (d/s). Could that be an issue?
Quick Reply: car goes into gear but wont move
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
