IACV unplugged and no code, 01' SH
Old Jan 3, 2015 | 06:21 PM
cityjack's Avatar
Default IACV unplugged and no code, 01' SH
Evening all,
I am in the midst of troubleshooting a idle issue. In the Helms as you work through one of the steps it says to unplug the IACV, I think as you are setting the base idle, it says you will get a DTC code. I get neither the code or a CEL. Anybody else have knowledge of this and why no code or light?
Thanks
Sid
Old Jan 3, 2015 | 07:33 PM
thirsk66's Avatar
Default Re: IACV unplugged and no code, 01' SH
It should have thrown a code. Try unplugging your map or tps sensor to make sure your check engine light bulb is not burnt out. Or you can jump your blue service connector down on the passengers side with a paper clip and see if your CEL light comes on.
Old Jan 7, 2015 | 02:51 PM
cityjack's Avatar
Bulb is fine. Works like a charm. No CEL or code when IACV is pulled.
Any other ideas?
Sid
vstone
Jun 1, 2010 09:29 PM
karrar55
Aug 29, 2009 04:52 AM
95sihb
Nov 14, 2002 05:28 AM
GeeSeeR
Aug 10, 2001 03:39 PM
