rough idle still
rough idle still
i fixed my fast idle thermo valve but now i have a rough idle and it stays at 15 grand. i noticed i wasnt getting full spark out of my third plug so i got new wires and distributor cap and spark plugs. still cant get it running right. all my hoses are new and i just bought an idle air control sensor. any help?
Re: rough idle still (dointhemzs2)
Sounds more like a timing issue, or all your spark plugs arent firing.
A video would help you out more.
What I want you to do, is go out side start your car, and pull the spark plug wires 1 at a time and replace it and do it for all 4. Look for changes in the motor when you pull the wire.
Your looking for nothing to happen when you pull a plug, that would indicate that one cylider is not firing, perhaps 2.
Re: rough idle still (Acidcrakker)
its the third spark plug. its not firing at full potential. thats why i got a distributor cap and wires and plugs. atill having this same problem
Do you install the plugs in the right order?
New rotar too. The spark should be present if you have it on all other cylinders. Try and switch the plugs around.
ArchAngel Sabastian
09-11-2002 09:29 PM
