speed sensor
i did do research. however i dont think i have a bad sensor but the connector that plugs into the vss looks like its melted somehow on one side. so i was wondering if anyone knows what it is called or where i could buy one thx.
mine went bad too awhile back and my speedomotre wasnt working at all..and i also had the carrosion in side too..i bought one off ebay u can use any prelude vss thats ur yea i think or one from a f22 gl
im located in vetura county. if you dont know where that is its about 50 miles north of LA. but the thing is i dont think its my speed sensor. ill see if i can get some pics b.c i think the problem is the connector that plugs into the speed senor..lt looks melted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mexicovi1la »</TD></TR><TR><TD CLASS="quote"> i think the problem is the connector that plugs into the speed senor..lt looks melted.</TD></TR></TABLE>
You cannot buy a connector by itself unless you have experience with electrical stuff and you have access to one of those huge connector catalogs. You would have to buy an entire engine harness to get one from Honda.
I would dig through a junkyard and find yourself another connector like that and cut it off. Then just solder it up to your existing wiring harness or you can remove wires from those connectors with a precision screwdriver set and replace the connector.
iblingidawg
Dec 17, 2005 11:18 AM
