Is this normal?
Old Sep 11, 2008 | 06:16 PM
nemesis25's Avatar
Default Is this normal?
Thanks for looking. I have a 97 Base with a little issue. Everytime, I start it up it blows light blue smoke for a few seconds(4-5) then it stops. So, I'd like to know if this normal? So far, Ive checked the plugs for oil burning/gunk but all the plugs are clean. Also, I was thinking maybe, coolant cuz I'm using Honda's Type 2 coolant which is blue in color. But then again, the coolant level has'nt dropped in the resovoir, significantly. Any input is welcomed!
Thanks again.
Old Sep 11, 2008 | 08:58 PM
no1knows908's Avatar
Default Re: Is this normal? (nemesis25)
Blue smoke is a sign of burning oil. From your description is sounds like your valve stem seals are leaking. When they go bad they drip small amounts of oil into the cylinder which burns off. Doesn't leak fast enough to create smoke while driving but as the car sits up all night it puddles in the engine.
Old Sep 11, 2008 | 10:47 PM
97ludedude's Avatar
Default Re: Is this normal? (no1knows908)
[QUOTE=no1knows908] From your description is sounds like your valve stem seals are leaking. /QUOTE] x2
91 Wagon
Apr 6, 2018 03:34 AM
187Chor
Dec 6, 2007 02:45 PM
ReV LiMiT
17
May 26, 2006 08:15 AM
druciferrr
Jul 5, 2005 09:17 AM
Tegster
Jan 9, 2005 11:01 AM
