keeps heating up????
my fan doesnt turn on causing my car to heat up i changed the cooling fan realy and it still doesnt turn on???
Modified by rohec04 at 7:37 PM 9/15/2008
check to see if power is getting to the fan when the fan should be switched on. or jump the terminals @ fan. 1 is power, the other ground, run wires from battery it doesn;t really matter if the are reversed, just touch them quickly and see if it turns. or heat it up and tap fan with hammer lightly. back yard styles though
Is your fan hooked up all the way?
Sounds stupid but me H22 decided to overheat one day in a traffic jam with 100ish* weather. Turned out the fan wan't hooked up all the way; the connectors weren't all the way together.
is your battery working well? maybe it wasn't installed right. Check if you're wirings are working. Maybe its grounded or something.
_________________
hyepermilers & gas savings!
_________________
i had the same issue i changed evrything new fan motor.relay,switch,thermostat,radiator,still overheats and then bought one of those grounding wires and 6 months now no overheat and my car runs like a champ
jonesEK
16
Mar 6, 2012 03:49 PM
mynameizstitch
10
Aug 30, 2007 08:15 PM
