Problem with start-up
Old Sep 11, 2008 | 06:53 AM
hydro606's Avatar
Default Problem with start-up
Hey guys, anyways i have a 97 honda prelude ss and it has 140k miles. it has an engine rebuld and i have already replaced the spark plugs, wires, rotor,cap etc. the car runs fine but some times the car will take a few moments for it to ignite and turn on. could it be that i need a new starter? it is pretty old.any help will be greatly appreciated
Old Sep 11, 2008 | 08:04 AM
97ludedude's Avatar
Default Re: Problem with start-up (hydro606)
prelude SH??? umm. . . is it cranking slowly or does it take awhile for the engine to start while turning over. . . is the cel on???
Old Sep 11, 2008 | 08:45 AM
hydro606's Avatar
Default Re: Problem with start-up (97ludedude)
both. it would take a little more to start. and no its not an sh, base prelude ss(sport shift)
Old Sep 11, 2008 | 09:15 AM
hydro606's Avatar
anyone?
Old Sep 11, 2008 | 10:55 AM
REDLUDE4WS's Avatar
check battery voltage if cranking over slowly. should be 12.6v or so and 14.2v while running. these are averages a <U></U>little<U></U> higher lower is not the end of the day. check it out, sounds like battery is sulfated/dying
Old Sep 11, 2008 | 11:04 AM
SKDRCR's Avatar
Default Re: Problem with start-up (REDLUDE4WS)
the battery shouldn't drop under 10 volts when cranking
Old Sep 11, 2008 | 11:34 AM
hydro606's Avatar
thanks guys ill check that out.
Old Sep 12, 2008 | 04:53 AM
2point2's Avatar
Did you mess around with the ground wires lately?
Old Sep 12, 2008 | 12:33 PM
jardolei's Avatar
I have the same problem. The engine turns normal but its like it won't fire for 1-2 seconds then it starts (but rough). This only happens once in a while, the rest of the time its perfect.
Changed: cap-rotor, distributer
Plugs max 1 year old (iridium)
Recent plug wires
Redid all the stock ground wires (the problem was there before anyways)
Battery is max a year old
I might change the plugs and see if that helps, but usually plugs last much more than a year! I realized that cylinder 3 plug had a little brownish color..
Did you check all your plugs?
Old Sep 13, 2008 | 07:27 AM
hydro606's Avatar
Default Re: Problem with start-up (jardolei)
well i finished installing brand new spark plugs,spark plug wires, cap, etc. i havnt checked the battery. sorry for the nOOb question, but where are the ground wires located?
Old Sep 13, 2008 | 08:21 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hydro606 &raquo;</TD></TR><TR><TD CLASS="quote">where are the ground wires located? </TD></TR></TABLE>
battery -&gt; chassis - &gt; tranny
valve cover --&gt; chassis
wiring harness -&gt; thermostat housing area
take out the starter and have it tested. Some of the parts store chains will have equipment to test them.
I've also seen a starter crank slowly because of a bad solenoid (which is sort of built into the starter).
Old Sep 13, 2008 | 08:43 AM
nsb823's Avatar
im having the same problem only mine is cranking but wont start i had it started 2 times yesterday took alot of cranking the it finally backfired and started rough any ideas
Old Sep 13, 2008 | 01:11 PM
hydro606's Avatar
Default Re: (nsb823)
Just finished checking the battery, the meter read as follows; 12.6 with the car off, 14.3 with the car on at idle. then it must be either the ground wires or the starter?
Old Sep 13, 2008 | 01:18 PM
Hawkze_2.3's Avatar
Is it cranking at a normal speed? If the starter was bad it probably would turn over like normal, it's either going to spin the engine or it's not....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ludedude &raquo;</TD></TR><TR><TD CLASS="quote">prelude SH??? umm. . . is it cranking slowly or does it take awhile for the engine to start while turning over. . . is the cel on???</TD></TR></TABLE>
Prelude SS is Sport Shift. Not the best reputation
KxiongEK
Mar 19, 2012 03:59 PM
SouthTexasRich
Jun 17, 2011 07:04 AM
qb1291
Apr 16, 2011 10:35 AM
leroyneal
Jul 2, 2010 10:08 PM
kriskonway
Sep 25, 2005 09:39 AM
