Timing Verification
Old Sep 24, 2008 | 11:12 AM
elude714's Avatar
Default Timing Verification
As mentioned in a previous post, my car is still having problems.
To verify timing is correct, does this method work. (car not running)
Rotate crank so the white mark on the flywheel is within sight, verify #1 at TDC and match that up to rotor being at #1?
Thanks
-MiKE
Old Sep 24, 2008 | 12:14 PM
REDLUDE4WS's Avatar
Default Re: Timing Verification (elude714)
pull off the valve cover check with arrows pointing up that the LINES on exh and int cam gears are across from each other perfectly. i don't like doing it the way you are explaining. leaves room for error. big flywheel to catch 360 degrees of rotation......twice
prelude2.2vtec
Mar 3, 2009 04:31 AM
deucedeuceEK
Jan 2, 2007 08:52 AM
b18c1civic95
Jan 1, 2007 06:25 PM
92 in the works
Feb 23, 2004 07:30 AM
bgod
Jul 23, 2001 06:37 AM
