Axle
Old Feb 19, 2007 | 07:07 AM
GReddy212's Avatar
Default Axle
Not sure what my problem is, hear a clunk noise when leaving from a stop position. Worst comes to worst how much will a whole new driver side axle replacement run me at a garage?
Old Feb 19, 2007 | 07:11 AM
hu's Avatar
hu
You can go to your local auto parts store. They cost ~ 70.00. Take it to a local garage and have them install it. Shouldnt run that much.
Old Feb 19, 2007 | 07:12 AM
GReddy212's Avatar
Thanks
Old Feb 19, 2007 | 07:33 AM
hu's Avatar
hu
There will be a core charge as well. It might be best to call your local auto parts store and order the axle. When it gets in, arrange to take your car to the shop to have the axle taken out. Then take the axle with you to the auto parts store so that you dont have to pay the core charge. Then take the axle to the garage and have him install it.
Old Feb 19, 2007 | 01:20 PM
doubledeucehatch's Avatar
please don't take it to a garage. It so easy to do. Get the axles. Pull both wheels off. under the bolt on the axle its like a 32 or 34 I think can't ever remember. You will have to have someone apply the brakes. Take the bottom ball joint nut of pry the ball joint with arm up. Then remove the 17mm bolt that connects the strut and move it out of the way. Then using a long pry bar go in from the top side and pry each axle out. Don't pull the axles out.
38genesis
Oct 22, 2009 10:07 AM
98GreenTegGSR
Jan 3, 2009 06:21 AM
MugenHonda
Dec 30, 2005 10:38 AM
dextR
Sep 16, 2005 07:49 AM
TheJunBuilt
Oct 15, 2004 08:32 AM
