H22A Euro-R rocker arms
have a couple rocker arms with too much wear, so i need 2 new rocker arm assy's.
the obd2 H22A Euro-R head (PDE code) is most similar to an H22A4, correct? rocker arm assys for H22A1 and H22A4 are different prices and part numbers, not sure what the difference is and which style the Euro-R used, so im not sure which to get.
ill be getting them from the dealer (hondaautomotiveparts.com), assuming theres no other cheaper source for OEM rockers, unless i find somebody parting out a head (i wish)
thanks for any help.
Re: H22A Euro-R rocker arms (Mykizism)
much appreciated!
now that makes me wonder why honda charges $40 extra for the a1 rockers.
that aside, Type-S and Euro-R shared similar internals, including cam profiles - ive read the thread about using type-s cams in a P13 head a while ago but cant find it, but now my concern is with wear related to having euro-r (basically type-s) cams with p13 rockers.
anyhoo ill of course measure and compare (ill have my machinist get more precise if need be) before installation. i tracked down a local set of H22A4 rockers that i will be comparing mine to, and if they match, i would assume i could pick from any H22 rockers.
