tps question
on my h22a i just recieved from hmotors, steve included a good tps for me since most if not all of them come crushed or damaged, however it is not on the throttle body.. i have heard that you have to install it with a voltage meter and get it set at a correct voltage... is that right or can i just put it in the slot and screw it in and be done with it.. just kinda curious.. thanks for any positive feedback on this guys.
yes you need to test the voltage before you tighten it in place otherwise you get a cel. .5v w/ the TB closed and 4.5 at WOT. If you have a vfac you can test it that way too.
