lsd?
Old Feb 12, 2007 | 12:32 PM
russianswty's Avatar
Default lsd?
Ok so I want a little more power out of my accord so I want to get a H22/23.
Im a noob to the h's so im not 100% sure yet. But I know im gonna want a
lsd in my tranny.
A few qestions about it.
Which tranny is build more tough? the h or f series.
Then which lsd would be better for daily driving, street racing,
good cornering, sometimes the strip. But pretty much a daily driver.
I was thinking of either a obx lsd or a stock one. The stock ones
ive seen go for about 2-3 hundred and the obx go for about 4-5
hundred.
And are the h and f series clutch's the same.
and are they the same in the length.
Old Feb 13, 2007 | 09:12 AM
Default Re: lsd? (russianswty)
anybody have any input?
Old Feb 13, 2007 | 09:23 AM
SOHC-VTEC-BB2's Avatar
you should search LSD and you will find a ton of info. and the FAQs has a ton of info on gearing etc for the diff trannies.
Old Feb 13, 2007 | 10:43 AM
4WSi_guy's Avatar
precisionh23a has a quaife for a reasonable price
https://honda-tech.com/zerothread?id=1815503
Old Feb 13, 2007 | 10:45 AM
Chuckles99SH's Avatar
If you get an H22 get the tranny from an H22, they did come with a stock LSD in japan so you can most likely get that tranny and not have to toy with OBX. The h22 tranny has a better gear ratio than an F series tranny. OBX is a cheap *** pos knockoff of the qualife. If you dont pull the thing apart and torque every bolt to spec you will most likely blow it up in your tranny. OBX = flaming pile of cheap poo.
Old Feb 13, 2007 | 11:04 AM
Default Re: lsd? (Chuckles99SH)
out of all the h series motors theres only one that came with a stock lsd.
But on ebay i did find an original lsd for only 250 bucks. But not having to
much experience with then I cant tell if its still any good, and if im getting
ripped of at at all.
Old Feb 13, 2007 | 11:45 AM
check out Hmotorsonline.com they can fix you up with a swap and they are very reputable. They offer LSD trannies with any of their swaps. Lots of members use em for their swaps.
Old Feb 13, 2007 | 12:20 PM
ECX's Avatar
ECX
* B A N N E D *
If I'm not mistaken:
-F-series tranny's are geared longer than H
-depending on if you want to boost the motor/keep it N/A really determines what tranny you should get. For an N/A car stick with the H22A trans (M2B4 I believe?), it's geared alot shorter so you can take advantage of the power. For a boosted car get something with longer gears. Honestly I haven't looked into transmissions or LSD's but hopefully I was of some sort of help.
Knightzero7
Transmission & Drivetrain
Apr 10, 2014 02:39 PM
TH22A1
10
Feb 12, 2010 11:03 PM
DiZwHaT
May 2, 2007 09:24 AM
mugensport9
11
Aug 27, 2003 08:58 PM
h22dc2
Apr 13, 2002 08:44 AM
