solid cel... is my ecu bad?
Old Feb 19, 2007 | 11:53 AM
TurboBA8's Avatar
Default solid cel... is my ecu bad?
I just finished my h23 head swap onto a f22 block. I got a basemap from a buddy and burned a chip. When I started the car I had a cel, so I turned the car off and checked the code. I thought it was a code 78, but that doesn't exist. So I thought I would try another chip just to see if that helped. So I burned another chip and started the car. I forgot to un-jumper the connector for the cel so I shut the car off and turned to car to the on position to try to recheck the code. This time it was just a solid. I undid the jumper for the cel and reset the ecu and the car will still start and idle, but it won't rev past 3k. So now it's in limp mode with a solid cel. The ecu is a chipped p75 running uberdata. Do you think the ecu is bad since I started the car with the jumper connecter?
Old Feb 19, 2007 | 12:00 PM
redtop22's Avatar
try burning another chip and test it out. also if you can get your hands on another ecu that would probably be the best way to determine if your ecu has gone bad, but i don't see how using a jumper would have messed up your ecu. perhaps the second chip you used is bad?
Old Feb 19, 2007 | 12:01 PM
kulrevon's Avatar
Default Re: solid cel... is my ecu bad? (TurboBA8)
Starting the car with the jumper connection will not make the ecu bad. but maybe they messed up when soldering in the board.
Old Feb 19, 2007 | 12:29 PM
TurboBA8's Avatar
Default Re: solid cel... is my ecu bad? (kulrevon)
i used the ecu for a year when i had the f22 turbo'd so i know it worked fine before. since this happened i have tried 2 other chips and nothing. only get a solid cel and limp mode.
Old Feb 19, 2007 | 12:37 PM
doubledeucehatch's Avatar
BUMP
Old Feb 19, 2007 | 12:44 PM
redtop22's Avatar
Default Re: (prelude252)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude252 &raquo;</TD></TR><TR><TD CLASS="quote">BUMP</TD></TR></TABLE>
another bump?
what happens when you try to check the code? is it possible you interfered with other parts of the ecu when installing/removing the chips?
Old Feb 19, 2007 | 12:50 PM
TurboBA8's Avatar
when i check the cel code, it is just solid... nothing inside the ecu has changed except the chips themselves.
Old Feb 20, 2007 | 04:49 AM
kulrevon's Avatar
Default Re: (TurboBA8)
try the ecu in a different car. or try a known good ecu in your car.
figure out if its your car or your ecu.
Old Feb 20, 2007 | 07:20 AM
flyrod's Avatar
Default Re: (kulrevon)
Probably a bad rom, bad connection to the rom (socket), or a problem with the modifications to the ECU done when it was "chipped" (bad soldering).
Old Feb 20, 2007 | 07:25 AM
mgags7's Avatar
or it could be the program on the chip, are you sure its written for the right ecu? if you put a p72 program in a p28 it will do this.
rick_rabies
Engine Management and Tuning
Aug 24, 2009 06:22 PM
erikiksaz1
Jan 17, 2007 10:39 AM
cheehee
Sep 6, 2006 05:02 PM
THEUSED
Apr 16, 2006 10:18 AM
acuracy r
Jan 3, 2006 05:56 PM
